06E17 - Diesel Forum - TheDieselStop.com
Old 03-14-2006, 09:49 PM   #1 (permalink)
06E17
Wow I havent posted here in a while. Been real busy.
Anyways, I just recieved the recall and was reading privous posts about what it entails I just want to know out of the guys that have had it done how did it turn out . Good- bad etc..
Also, considering my truck was last reflashed August of 2004 at the same time the EGR was last replaced with only 13,000 mi. (It now has 46,000 and these repairs were done before I owned the truck.) Should I really make them fix it or wait until it fails. Im not shure if the flash thaty was done at this time was one of the ones considered a good flash or not. I know I get about 13.5mpg around town and 17 at best on the hwy so if this flash gets me better mpg Im all for it.
2003 F-250 XLT, Crew Cab, SWB, 6.0 TorqShift, ESOF, Limited Slip, Silver,.
Truck Weight Wet, No Payload:
Steer: 4380 lb Drive: 2920 lb Gross: 7300 lb
TRUCK PICS!
Mods:
LINE-X, SteveracerMOD, Autometer Boost-Pyro; A-Pillar mount, MBRP 4" Turbo Back (What's A CAT?) Polished CAC tubes, Custom Heavy Duty Headlight Harness and Silverstar Bulbs, Heavy duty bumpers I built
RockPSD is offline
Old 03-14-2006, 11:01 PM   #2 (permalink)
Re: 06E17
Rock,
There are 4 active posts in this section on 06E17. Its been discussed alot in the last 2 days. Scroll down a bit, You'll find hours of reading.
OMCUSNR is offline
Old 03-14-2006, 11:04 PM   #3 (permalink)
teamroper60's Avatar
Re: 06E17
As noted above, there are several active threads on this topic, so I am closing this one.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
