07 f450 6.0 no cranking low oil pressure - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 05-23-2012, 02:26 PM Thread Starter
After oil change truck died on road towed back to shop had low icp pressure furthur testing revealed no cranking oil pressure for the first 15 to 20 sec then starts pressure reg spring looks good.please help.
fleet diesel tech.
thw1 is offline
post #2 of 15 (permalink) Old 05-23-2012, 02:30 PM
dieselmac's Avatar
Did you use an OEM filter? still have the OEM filter cap?
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #3 of 15 (permalink) Old 05-23-2012, 06:10 PM Thread Starter
No used napa filter and cap the tube in the filter housing was cracked waiting for dealer dilivery
fleet diesel tech.
thw1 is offline
post #4 of 15 (permalink) Old 05-23-2012, 09:14 PM
dieselmac's Avatar
Don't do anything else until you get an OEM cap and filter.
The aftermarket cap & filter combos cause all kinds of problems. I'd bet the filter is not fully closing the drain valve in the bottom of the housing which allows oil to drain from the housing as fast as it's trying to fill.
Scott
post #5 of 15 (permalink) Old 05-24-2012, 03:21 PM Thread Starter
Replaced oil filter and cap with oem truck started after a few cranks has good oil pressure road tested good parked truck to check for leaks did not re start 100 psi icp .pressure test hop system should system hold steady pressure or bleed off cant hear any leaks ?
fleet diesel tech.
thw1 is offline
post #6 of 15 (permalink) Old 05-24-2012, 05:25 PM
Sorry to say either you damaged the low pressure pump by not running enough oil to it or ya damaged the hpop from starveing it of oil, sad to sy it will probably be the hpop.
dannyboy950 is offline
post #7 of 15 (permalink) Old 05-25-2012, 11:08 AM
rockfish71's Avatar
Stc fitting possible has it been hard to start cold and and a little delay when hot?
Tousley Ford Parts Depot
6E7Z-9A332-B Stand pipe kit
contains two standpipes, two dummy plugs
rockfish71 is offline
post #8 of 15 (permalink) Old 05-25-2012, 05:41 PM Thread Starter
Stc fitting on a 07 ? HPOP GUESS I NEED TO DIG. I also have head gasket leaking oil both sides easier to pull engine 07 no cab removal
fleet diesel tech.
thw1 is offline
post #9 of 15 (permalink) Old 05-25-2012, 08:18 PM
Are you asking if an 07 has the STC fitting?
Mark
bismic is offline
post #10 of 15 (permalink) Old 05-25-2012, 10:23 PM
dcovaleski's Avatar
How are the headgaskets leaking oil??
Sent from my Autoguide iPhone app
2005 F-350 cc, 6sp, 4" turbo back MBRP, 03 turbo, ARP studs, Sinister EGR delete, Southbend clutch, SCT with custom tunes and really bald tires
1996 F-350 Reg cab psd auto 187k so far so good
dcovaleski is offline
post #11 of 15 (permalink) Old 05-26-2012, 10:57 AM Thread Starter
yes do they have the problem fittings. The heads are leaking from the rear lower corners .
fleet diesel tech.
thw1 is offline
post #12 of 15 (permalink) Old 05-26-2012, 01:02 PM
Be shure that the leak is not somewhere up forward and just running down the gasket edge and showing up there before ya go pulling heads..
post #13 of 15 (permalink) Old 05-26-2012, 05:39 PM Thread Starter
Yes i will double check did lots of cleaning i added dye will re check after holiday still bettr to remove engine to service heads ? this truck has engine mounted hydraulic pumps also ? Idid a leakdown on the hop system should it hold pressure or leak out fast ?
fleet diesel tech.
thw1 is offline
post #14 of 15 (permalink) Old 05-29-2012, 10:42 AM Thread Starter
Pressurized hop system in a quiet shop this morning heard leak under pas side valve cover looks like fun hydraulics cover the valvecover, oil leak is comming from somewhere around oil cooler cant see the front any tips?
fleet diesel tech.
thw1 is offline
post #15 of 15 (permalink) Old 05-29-2012, 07:06 PM Thread Starter
Valve covers off presurized system still dont see any leaks Iwill keep digging
fleet diesel tech.
thw1 is offline
