07 f550 died while driving - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 09-20-2010, 03:16 PM Thread Starter
my 07 f550 died while driving on the highway, base oil pressure went to zero on dash, checked oil pump regulator it was stuck open got it out cleaned up burrs on regulator put back together, crank engine after 5-8 sec get oil pressure on gauge but truck doesnt start. havent had any starting problems before. ive tried for two days to get truck to start.can losing base oil pressure cause any hpop failures.
celticcross1770 is offline
post #2 of 12 (permalink) Old 09-20-2010, 03:22 PM
Unreal04's Avatar
Try the FCIM test to see if its putting out low voltage. The oil gauge on your dash is your low pressure system. Mine doesn't even move until the truck is running for 10 seconds or so.
Unreal04 is offline
post #3 of 12 (permalink) Old 09-20-2010, 03:25 PM Thread Starter
is the fcim the injector module on the valve cover
post #4 of 12 (permalink) Old 09-21-2010, 03:27 PM
Ranger_713's Avatar
Yea the FICM is on the drivers side valve cover rear.
Values are typical and may vary by 10% depending upon current altitude, accessory operation, engine load, operating time, temperature, and vehicle speed.
Ranger_713 is offline
post #5 of 12 (permalink) Old 09-21-2010, 05:09 PM
cmirabile's Avatar
My Photos: (9)
If you lost low pressure oil, then you stopped feeding the HPOP reservoir. It would probably crank for a while before it started back up. I would check the voltage at the ICP Sensor and find out if your getting 500PSI
2005 F-350 XLT PowerStroke Diesel FX4
SCT Xcalibrator2 with Tunes from Innovative Diesel
37 X 12.5 BFG Mud Terrains
5% 3M Tinting
Viper 791XV with Remote Start
152dB Kleinn 3-Trumpet Horn System
Dakota Digital Gauges
T409 MBRP Straight Pipe
AFE Stage II Intake
HARPOONED Fuel Tank
2003 10 Vane Turbocharger
Blacked Out Harley-Davidson Edition Headlamps
ARP Head Studs
AVIC-Z2 In-Dash Navigation System
205cc Elite Sticks
Coolant Filter
Elite Regulated Return Fuel System
FS2500 Oil Filter
HPOP STC Replaced
cmirabile is offline
post #6 of 12 (permalink) Old 09-22-2010, 05:25 AM Thread Starter
thanks i will check hpop pressure and icp voltage. is there any way of checking or prefilling the hpop resevoir like on the old 7.3
post #7 of 12 (permalink) Old 09-23-2010, 07:54 AM Thread Starter
checked hpop pressure o psi with scan tool and mechanical gauge. could my hpop screen be plugged with debris. is there any way of checking for a full resevoir without pulling it apart
post #8 of 12 (permalink) Old 09-23-2010, 08:14 AM
bobbywalter's Avatar
why is there that much crap in your oil?
something is not stirring the koolaid with that oil bud. is it coolant contaminated or anything?
1988 ford ranger ext cab, 4x4. 6.5 gm diesel motating a 4l80 brutalizing a ford 208 spinning 410 dana 60's with whatever size tire needed to get the job done.......so how ya lke me now??
bobbywalter is offline
post #9 of 12 (permalink) Old 09-23-2010, 08:21 AM Thread Starter
coolant is clean had three injectors replaced and hpop 6 months ago could there be still debris floating around after 4 oil changes
post #10 of 12 (permalink) Old 09-23-2010, 08:43 AM
damn....i must be lucky.
while i obviously rarely post....the **** i see in here ...there is no way i would ever pay 40- 50k for a truck that is one trainwreck of a problem after another.
i still have my 95 with over 800 k on it, the o5 was short lived in our possession but excellent running and put over 100k on it in 14 months between us.... it did end up studded and egr deleted with custom tune though by the next owner who dumped it after the tranny died for a d max that sits at the dealer 3 months out of the year. i dont know who has it now but i bet they love it cause it has never let em down with a fresh tranny and cured 6.0 .
must be nice for these poor bastages making 1 k payments for a dealer lot ornament.
post #11 of 12 (permalink) Old 09-23-2010, 08:54 AM
cmirabile's Avatar
My Photos: (9)
I think itís highly unlikely that the HPOP Reservoir could be so dirty so as to prevent oil flow to the HPOP. I think either have an empty HPOP Reservoir or a bad HPOP. Iím still voting for the empty Reservoir though. I think if you pull off the filter and pour oil straight down the housing it will go straight into the HPOP Reservoir, Iím not 100% though I could be completely wrong. The only way to check the reservoir would be to pull the oil cooler off and thatís not an easy 1-2-3 job.
Try this: loosen the oil filter cap and have an assistant crank the engine, Then stop cranking and see if there is any oil getting into the filter. Thereís a possibility your just not getting any LP oil still
5% 3M Tinting
AFE Stage II Intake
HARPOONED Fuel Tank
ARP Head Studs
205cc Elite Sticks
Coolant Filter
FS2500 Oil Filter
HPOP STC Replaced
post #12 of 12 (permalink) Old 09-23-2010, 11:09 AM Thread Starter
pulled oil cooler housing off had oil in resevoir screen a little dirty but not enough to block flow. pulled ipr and screen broken and valve is seized with debris from screen on end of valve. can a hpop fail that quickly only have 20k on it sinc last hpop.
