1750 RPM Rattle - Diesel Forum - TheDieselStop.com
Old 11-02-2009, 03:31 PM   #1 (permalink)
1750 RPM Rattle
First Post!
Glad to have found the site! What a great resource for diesel owners.
I just recently purchased the truck in my siganture. I currently have 57K miles on the odometer.
I have recently noticed that at 1750 RPM there is a rattle coming from under the truck. Maybe the turbo...not really sure. When I accel or decel past 1750-1900 RPM it goes away. Comes right back anytime I hit 1750 RPMs. Is this normal or an indication that a somehting is getting ready to fail? There are no other symptons present at this time.
BTW, I am competely satisified with this truck and its performance so far.
Any help is greatly appreciated.
Thanks!
2006 F-250 6.0L Crew Cab FX4
RigRunner is offline
Old 11-02-2009, 06:08 PM   #2 (permalink)
Sounds like you MAY have a harmonic in the exhaust system. 2003s had this a bunch, including mine. Ford came out with a new pedestal for the turbo and that fixed many. For mine I just added a tip to the exhaust which moved the harmonic down the RPM band to where I never noticed it.
Roy
2005 Limited, 6.0L PSD, 4X2, Mineral Gray, 3.73 LS. Excursion Build date 02-08-05 6.0L 2005MY Engine Build date 01-03-05 Huntsville, Ala.
2005 50th anniversary Thunderbird Red with all
options except hardtop.
Old Ride: 2003 Excursion 6.0 L March 2003 Build 73,000 with no significant issues.
RoyC is offline
Old 11-02-2009, 08:42 PM   #3 (permalink)
Thanks Roy. I have not considered that the muffler may be causing the rattle (harmonic). I will check into that.
I failed to mention that truck does have an aftermarket exhaust (which I have yet to identify the mfg) and tip.
Guess I shold remove "stock" from my signature.
What is the easiest way to identify the mfg of the exhaust? I have looked up and down the exhaust and can't seem to find any indication of the mfg.
