My 6.o Has 50,000 Miles On It. The Wife Is Driving It Up To Austin. It Is Surging And Sputtering(her Words) Between 65 And 70. Seems To Run Smooth At Higher Speeds. Any Ideas.
Fuel filters and oil and oil filter would be my 1st choice. Make sure to use OEM Motorcraft or racor filters. Do not use AM except for Fram CH9549. It is also made by Racor. Once you have this problem ironed out I would service the rest of the truck so that you have a basis to work from. The 6.0 can be a good engine but it is very finicky when it comes to proper maintenance.
Start w/ changing the fuel filters. They MUST be changed at 15k intervals and SHOULD be changed at 10k intervals. Fuel pressures below 45 psig can permanently damage injectors.
Make sure to use OEM Motorcraft or racor filters. Do not use AM except for Fram CH9549. The 6.0 can be a good engine but it is very finicky when it comes to proper maintenance.
This is very important, I know a company in my town that has a fleet of 6.0s and started w/ the aftermarket filters and had nothing but problems.
__________________ 3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
