2003 6.0 Terrible Starting Any Temperature - Diesel Forum - TheDieselStop.com
Old 07-08-2007, 02:23 AM   #1 (permalink)
RTX
I have an 03 6.0 that's been a good truck overall but lately every start the truck acts like its 0 degrees outside. It is impossible to start the truck and run it until it has idled for at least 15 minutes, at which time the idle smooths out and sounds fine. Once the truck is going down the road and is warmed up everything runs fine the rest of the day but if i take off before it has warmed up it will have no power and be very sluggish. It can be restarted all day and does good but if it sits for a few hours and gets cold(although its 95 degrees outside) it will have another terrible,rough start that jumbles around for 15 minutes until it gets warm again. Any ideas greatly appreciated because the local dealer has been no help........
RTX is offline
Old 07-08-2007, 02:33 AM   #2 (permalink)
Texrob1's Avatar
Send a message via Yahoo to Texrob1
Re: 2003 6.0 Terrible Starting Any Temperature
When was the last time your fuel filters were changed?
2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
Texrob1 is offline
Old 07-08-2007, 03:46 AM   #3 (permalink)
I'd take it to the dealer and get TSB# 07-05-04 performed. That will update the PCM, FICM, and TCM to the latest calibration level including the fuel injector induction program. This strategy does work well. The other day I had a E-Series that would not start, or try to start at times, and it had the "buzz" strategy installed. I updated the PCM, FICM, and TCM and the van ran perfect after that.
I'm a mod friendly Ford Diesel Technician located in Sacramento California area.
Gofaster23 is offline
Old 07-08-2007, 08:56 PM   #4 (permalink)
My was doing that until I took it in and had the PCM reflashed with updates. Now it starts Like a champ every time, no matter what out side temp is. It help mine out.
03 FORD 250 SD FX4 6.0
BOUGHT 11/06 WITH 135K MILES.
I LOVE MY TRUCK.
Life isn't like a box of chocolates..... more like a jar of jalapenos. What you do today, might burn you tomorrow !!
Catfishin is offline
Old 07-09-2007, 11:52 AM   #5 (permalink)
RTX
I appreciate the info. I will take it in and have that flash done....for the record the fuel filters are only about 6 months old..maybe 10K on them....thanks again
RTX is offline
