2003 6.0L Coolant leaking from the water pump I believe! - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 08-13-2010, 05:47 PM Thread Starter
The coolant on the truck is leaking. The coolant is dripping out over the crankshaft pulley. I think it is from the water pump and/or its weap hole. I does not leak when you first start it up and until it heats up. Also, does not leak when it cools down. But I am curious is it possible that the thermostat is jammed and this is what is making the water pump leak?
Guber6 is offline
post #2 of 5 (permalink) Old 08-13-2010, 05:55 PM
paintingman's Avatar
most of the time when it leaks it's time to be replaced at least on mine that was the case
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
post #3 of 5 (permalink) Old 08-14-2010, 02:12 AM
No its the shaft seal leaking. The weep hole is on top of the pump casting.You cannot see it because the pulley is covering it.Done alot of them in Internationals not fun but entirely do-able. but there are way worse things to repair on this engine you would not want any part of trust me Remember the fan hub is left handed thread.If you dont have the tools to do it dont torture yourself Lol.............
07,F-250 4X4 6.0 Torqshift, Lariat, Highline package, S/C LWB.
grounder is offline
post #4 of 5 (permalink) Old 08-14-2010, 09:53 AM
speedrcr78's Avatar
Had the same leak tore my truck down only to discover that it was the water temp sending unit that was leaking. I just went ahead and changed the water pump anyway. I think it is common for that sending unit to leak. The path the water took made it look like the water pump.
speedrcr78 is offline
post #5 of 5 (permalink) Old 08-14-2010, 11:10 AM
the top hose on my thermostat was leaking and the coolant some how made it to the bottom of the crank.
f350fedx is offline
