Old 10-16-2009, 08:45 PM   #1 (permalink)
2003 6.0l dead
My 2003 6.0l is dead. It has been starting up rough, idling rough and cutting out when giving the gas for the past couple weeks, after you drive it for a few miles it will all clear up. It got to the point to where it wouldnt start. So after trying to start it up for a couple of days it finally started and I took it to a 6.0l mechanic. He started by changing out the icp, which was leaking out oil. This did not fix the problem so he suggested that I took it to ford to get the program flashed, I have a edge on it that has been cutting on and off for a couple of months now so we took it off before he changed out the icp. So I took it to the ford dealership and they hooked up the laptop and all 8 injectors were faulted out. After flashing the program the codes came back. I then left to go home and my truck broke down on me, so I got it towed back to the dealer. They then replaced the ficm and checked the codes and now only 2 injectors are alarming. The truck started but still not running right. They now suggest that all 8 injectors need to be replaced along with the hpop, I went to pick up the truck and it would not crank. They are saying that my hpop is creating metal shavings which is getting to the injectors. Does any of this sound true and what would you do. I will have around $6500 tied up if I do what they suggest. I just want it running so I can sale it.
rshelton42 is offline
Old 10-16-2009, 08:47 PM   #2 (permalink)
Texascadillac42's Avatar
My Photos: (10)
If the HPOP is coming apart, then there would be alot of metal debris stuck in the screen at the end of the IPR. Knowing what IPR duty cycle is, and what pressure the ICP is seeing while cranking would help diagnose....
99 F350 XLT 4x4, Crew Cab, 6spd, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
Texascadillac42 is offline
Old 10-16-2009, 09:01 PM   #3 (permalink)
sorry the ipr did get replaced and they did show me some sort of screen that was filled with oil, do you think that the dealership checked pressures before determining that I needed a new hpop
Old 10-16-2009, 09:40 PM   #4 (permalink)
My Photos: (10)
They certainly should have. If the IPR screen was intact and not full of metal than the HPOP may not be coming apart. But it also could be, its tough to say. They certainly should have checked the pressures, and done an air leak test to determine if and where any air leaks in the HPO system are.
That metal screen is designed to catch any metal that might come from the HPOP, so if the screen is intact, I find it hard to believe that all 8 injectors have failed due to metal from the HPOP.
Old Yesterday, 02:01 PM   #5 (permalink)
6.0l f250 loss of power
Ford dealership found out that the hp oil pump was bad. It was replaced and the truck ran good for a couple of weeks. Now the truck has a loss of power, over the past week the truck has only ran good for 1 out of 7 days. Any ideals why my truck has all the sudden lost power?
Old Yesterday, 03:43 PM   #6 (permalink)
MikeL46's Avatar
That's a little bit like telling the doctor you don't feel good and expecting him to know what is wrong.
More specifics could help.
You could have bad fuel, bad fuel filter, bad O-rings on the injectors, low fuel pressure, loose turbo hose, or a whole host of other issues.
Mike
125W solar panel. Sportsmobile off-road trailer.
71,257 miles. 16.49 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge DieselSite Coolant Filter
165 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, Batteries not under warranty.
MikeL46 is offline
Old Yesterday, 09:41 PM   #7 (permalink)
F250crazy's Avatar
More info please. When does the truck run bad? cold or hot? any certain speed? Boost or no boost? That kind of info.
F250crazy is offline
