2003 6.0L Won't start when hot (sometimes) - Diesel Forum - TheDieselStop.com
Old 12-01-2010, 07:34 PM   #1 (permalink)
Engine starts fine when cold, but sometimes after driving it for a distance sufficient for it to warm up it will not start. Starter turns motor fine. One time when it wouldn't start, I disconnected the batteries for 15 minutes and it cranked. It has acted up since then, and as I work out of town and my wife drives it, I have not been able to try this again to determine if the act of disconnecting the batteries temporarily solved the problem or it was merely a coincidence. She has taken the truck to a local Ford dealer who have duplicated the starting problem but say that they can't get an error code to come up on the computer. They think it is the fuel pump, but from what I have been told have not put a gauge on the fuel line to confirm their diagnosis. Has anyone else experienced this problem, and if so offer their solution. I have read and forwarded to the Ford mechanic the Troubleshooting a "no Start" condition list from this site. Thanks in advance for any help.
notaone is offline   Reply With Quote Quick reply to this message
Old 12-01-2010, 08:22 PM   #2 (permalink)
sarnott140's Avatar
dummy plug or hpop problem
'06 F350 CC, SB, 6.0
Oxford white, scangauge 2, 3" lift, egr delete, stc upgrade, dieselsite coolant filter, high idle mod, skyjacker s/s,deezee nerf bars and drybox, 305/65-18 BFG all terrains, Hella driving lights and fog lights.
sarnott140 is offline   Reply With Quote Quick reply to this message
Old 12-02-2010, 05:41 PM   #3 (permalink)
69cj's Avatar
Not saying it is from here but the 03's are notorious for ICP problems causing this.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline   Reply With Quote Quick reply to this message
Old 12-10-2010, 09:03 PM   #4 (permalink)
Have you got your truck fixed yet? Did they finally put a gauge on the fuel pressure test port?
I went round and round with a service manager when my truck was haveing issues with the HPOP system. I wanted them to put a gauge on the HPOP and they refused stating "Ford doesnt recommend using a gauge." How stupid could they be? Or how stupid do they think I am?
Anyway, I finally had to fix it myself. Never again will my truck go to a dealer.
To make a long story short, my HPOP had a blown o-ring and thus wouldnt make full pressure when oil was hot. Stone cold it would start but not when hot. P2285 (Low ICP) would only sometimes show up.
I now have mechanical gauges on Engine Oil Pressure, High Pressure Oil, Fuel Pressure and Coolant temp. I'm hoping Santa will bring me some more goodies.
'03 F250 6.0L 2wd all stock, 160k miles...
Its just a machine and machines CAN be fixed.
Just an everyday driver work truck.
Tow big RV trailer for fun.
Fixinitmyself is offline   Reply With Quote Quick reply to this message
Old 12-11-2010, 09:06 AM   #5 (permalink)
Definitely check icp voltage koeo, these are a huge issue on an 03 with the icp sensor located under the turbo. It is usually worse with engine hot also. Check your icp votage with a scan tool with key on, engine off when it is hot. Should be between .18 and .24 volts, anything lower is no good. Also, crawl underneath an look up at sensor (left hand side of vehicle, above bellhousing) to see if it is leaking, this is another indicator the sensor needs replacement. Replace the sensor AND connector at the same time.
djshum is offline   Reply With Quote Quick reply to this message
Security Question
*Required, this field is not shown to others. "While balancing on a piece of wood, two inches by four inches known as a 2x4, john and his friend sally both spotted a dalmatian inside a truck with sirens, headed to put out a fire. State what the 2x4 is made of. "
Insurance
Please select your insurance company (Optional)
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
