2003 F250 rear end rebuild? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 06-29-2012, 11:05 PM Thread Starter
Just recieved a quote from my local shop regarding a rear end issue with my 80K mile truck. Issue: speed dependent high pitch whining sound from rear end. Diagnosis: Worn carrier bearings. Suggested repair: Full rear end rebuild (carrier bearings, pinion bearings, differential clutch pack, seals, lube etc.) Quoted cost: $1250
Does this seem like a reasonable price for the labor
/parts involved? The service tech said it would take ~5 hours labor + parts. Should I request the failed bearings to see if they truely are worn out as they claim? I normally would not question their diagnosis but my dad (45 year Ford dealership mechanic - retired) says that my described symptom (i.e. high pitch whining) does not sound to him lilke a carrier bearing issue. I already authorized the shop to do the work but after talking to my dad I am now a little suspicious of their repair quote. If there was metal shavings in my rear end from the worn carrier bearings wouldn't that result in speedometer and anti-lock brake sensor issues as well as rear end noise?
wsu0702 is offline
post #2 of 3 (permalink) Old 06-30-2012, 12:16 AM
dcovaleski's Avatar
Well depending on who you talk to, the "carrier" bearing is also referred to as the drive shaft center bearing. Do you have a two piece drive shaft? If so...I would look there first. Rear axle failures are extremely rare...if not next to impossible on these trucks. There will always be metal shavings on the magnet in the diff fluid, ive never seen one that hasnt.
Sent from my Autoguide iPhone app
2005 F-350 cc, 6sp, 4" turbo back MBRP, 03 turbo, ARP studs, Sinister EGR delete, Southbend clutch, SCT with custom tunes and really bald tires
1996 F-350 Reg cab psd auto 187k so far so good
dcovaleski is offline
post #3 of 3 (permalink) Old 06-30-2012, 09:36 AM
DWL/03/PSD's Avatar
Seems fairly reasonable.
*** I was fairly surprised when I replaced my l/s with an eaton locker to see how absurdly tight the carrier (bearings that support the cage /carrier that houses the l/s, or spider gears) were. I had just under 72,000 miles on the truck and the bearings were all gaulled and showing heavy wear. I think they used a 10# sledge to put the spacers in at the factory. I should have pulled and replaced the pinion bearings / races at this time, but they felt ok.
3,000 miles later had a slight vibration, ended up being the pinion bearings. What a way to dump 4 qts. of synthetic gear lube in the drain pan. ***
Surprised you heard a noise.... truck is so noisy in the first place.
The diagram shows an open diff, but the major parts are the same.
They are going to change # 2 side bearings, # 8pinion bearings. 2 sometimes being called carrier bearings.
Either way, you should get a 1 year warranty on parts/ labor on a dealer performed service? I hope.
Good luck.
PS I love my eaton locker... no more embarrising moments getting stuck on wet grass or towed out of muddy camping spots towing camper
2003 F-250 :: Born 12/12/02
2 WD Super Cab, Super Duty
8' box. My daily driver!
Only
filters and just switched 10/2010 to Shell Rotella 5w/40 synthetic from Rotella T 15w/40
Edge Insight Guage w/ dash pod,W/ pre-turbo Pyro, Dieselsite coolant filtration system, High idle mod., way too many extra lights...
1 turbo cleaning 6/07 from lot rot waiting for me to find her 45,000 mi.
4 ball joints: Ford ESP extended warranty
D-B 190 Amp. alternator What a difference!
Eaton (Detroit) Locker Rear Differential All new bearings / seals
I drive it like I stole it and love every minute behind the wheel. Almost as much fun as riding the motorcycle
DWL/03/PSD is offline
