2003 Fuel Pump Replacement - Diesel Forum - TheDieselStop.com
Old 10-30-2009, 12:06 PM   #1 (permalink)
I have a dead fuel pump, and the updated 2006 part does not have the connection for the heater. Dealer says I have to buy a new harness that eliminates the connector for $18. Do I need the harness, or can I just cover the extra connector? I assume the new harness has a resistor in it so it does not set a heater code. Or should I swap the new fuel pump into the old housing and keep the heater? It does get cold here in MI.
2003 F250 FX4 S/C short box 6.0L diesel, 125K miles
mike_s_82 is offline
Old 10-30-2009, 02:16 PM   #2 (permalink)
personally, I would pull the pump out of the new housing and put it in the old housing after cleaning it up. Thats just me though
2004 F250 CC FX4 175k miles and counting
reprogrammed egr Innovatives programming
straight piped Airaid intake harpooned tank
hooknline is offline
