2004 6.0 question - Diesel Forum - TheDieselStop.com
Old 10-31-2009, 01:23 PM   #1 (permalink)
2004 6.0 question
so my buddy just bought a 2004 F-350 6.0 with 116,xxx miles on it, the truck seems to run really good and everything seems to work fine, but it does something I've never seen before. So when you turn the key on when it's cold you can hear the glow plugs and injectors and what not under the hood, which is normal but after running it he shuts the key off and you can hear the same noise after it shuts off. it runs for approx 30 seconds with no key in the ignition. any ideas?
2003 ford f-250 fx4 PSD 6 speed extended cab long box
4" MBRP cool duals
Sct X3 with custom tunes from ID
Autometer phantom 2 pyrometer and boost gauges
2.5" lift on 35's
Jared583 is offline
Old 10-31-2009, 01:33 PM   #2 (permalink)
it was a recall on some of the engines i have it on 2 of my trucks
strokerman11 is offline
Old 10-31-2009, 01:36 PM   #3 (permalink)
should he just bring it to the dealer? he just bought the truck last night so he doesn't have any recall info
4" MBRP cool duals
2.5" lift on 35's
Jared583 is offline
Old 11-01-2009, 02:26 PM   #4 (permalink)
teamroper60's Avatar
He has the flash that "shook" the spool valves in the injectors at shut down. There is nothing wrong with it.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 11-01-2009, 02:53 PM   #5 (permalink)
Strokin' 6.0's Avatar
According to my indy mech, that is a good thing...in case any water whatsoever were to get into the fuel and past the separator, the injectors are able to "spit" everything out.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Strokin' 6.0 is offline
Old 11-01-2009, 03:32 PM   #6 (permalink)
so there's nothing wrong with it? i've never heard a 6.0 do that before
4" MBRP cool duals
2.5" lift on 35's
Jared583 is offline
Old 11-01-2009, 06:16 PM   #7 (permalink)
What?????????????????
Since the engine is not running when this is happening, there is no high pressure oil. Without high pressure oil, nothing gets injected, so nothing could get "spit out"....
The flash that shakes the spool valves was only used for a short period of time. That's probably why you haven't heard it before. There is nothing wrong with the flash or what it does. But folks complained about the noise. Ford then brought out the "inductive heating" flash to heat the spool valves instead of shaking them. Both flashes were created to deal with rough running on cold starts.
pics
#43
Old 11-01-2009, 06:27 PM   #8 (permalink)
69cj's Avatar
It was commonly referred to as the buzz flash and hurts nothing. It is, as stated above, the predecssor to the inductive flash. It helps with a phenom called injector stiction that affected cold starts. It is all done electrically thru the injector spool valves. It is supposedly easier on the FICM than the inductive flash. That is still being debated however.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 11-01-2009, 09:01 PM   #9 (permalink)
OT
OT's Avatar
J..INDUCTIVE HEAT (F.I.) FLASH
FWIW...tuner at PHP said fmc updated the inductive heat flash hoping it will eliminate failures of ficm's. For those with this inductive strategy & had ficm failure (possible premature) maybe that is why?
I still have orig. f.i. buzz after shutdown (done 11/06) & for all that do maybe its good we have it, but? Apparently its just inductive flash as being suspect at this time. Anyhow, seem's another crap shoot has been created by fmc.? JMO!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 11-01-2009, 09:05 PM   #10 (permalink)
thephoneguy's Avatar
Just a temporary solution...
Turn it off in gear if its automatic transmission until a mechanic can determine the problem.
thephoneguy is offline
