2004 6.0L recalls?? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 09-17-2006, 04:03 PM Thread Starter
2004 6.0L recalls??
Is the Ford Motor Company website the best place to go for vehicle recalls. I have had only 1 recall ( notified from Ford) on my 2004 6 liter but people tell me there are more. Where can I check for others??
ckhanna1 is offline
post #2 of 8 (permalink) Old 09-17-2006, 05:47 PM
Re: 2004 6.0L recalls??
The MyFord website where you setup your profile with your truck's vin # (as well as any other ford vehicles you might have) will list "recalls" that effect your vehicles. The other items that others might be talking about are most likely "TSB's" and the like which might effect your vehicle but are not classified as a "recall"
Mntsnow
04 F250, Lariat, CC, SB, SRW, 6.0L, TorqShift, FX4, 6-way Power Heated Leather, 3.73 LS, ESOF,Tow w/15K hitch, H & L TT mirrors, Adj pedals, Reverse sensors, Privacy glass, Cab steps, Sliding rear glass, Overhead console, Advanced Security group, Medium Wedgewood Blue Metalic w/Arizona Beige Accent paint. 325/70/17 Toyo Open Country AT's, Pro-Comp 6.5" All spring lift, 4" Cat-back exhaust, Fumoto Valve, Harpooned, Zoodad, Steveracer, $5 High-Idle mods, Pioneer DEH-P7500MP, CS8A5 Bazooka Tube, X-Monitor Digital Gauges, Viper 5900 Responder SST remote start security system and more to come!
Truck Build Date 8/03, Engine build date 8/20/03, Bought 11/09/03
Mntsnow is offline
post #3 of 8 (permalink) Old 09-17-2006, 07:40 PM
What exactly is the MyFord website. I,m not familiar with this.
2013 F350 KR,LB,SRW,4X4,Blue Jean Blue,Moon Roof,Tailgate step,Upfitter Swtch, 5th whl, Bak Flip F1, whl well liners,splash guards
Old Truck:
2004 F350 KR,LB,SRW,4X4,18" wheels - Loaded,
Added: Line-X, Isspro EV gauges, Prodigy, C-BETR mirrors, Huskey liners, PIAA-1500 Back-Up, Rancho 5406, RETRAX, Fumoto, XM Radio
Older Truck:
1999 F250 Lariot, SB, 7.3, Linex, Bullet Proof
RootDoc is offline
post #4 of 8 (permalink) Old 09-17-2006, 07:48 PM
overfly's Avatar
My Photos: (16)
Go here to check it out.
2006
- Amarillo Package,loaded with all the toys, 4" MBRP cat back exhaust, Autometer EGT gauge, Viper 791XV auto start/cool down timer/alarm, Pioneer AVIC-D3 navigation/XM Radio/Sirius, 2.5" Tuff Country Leveling kit, KC Hilights front & rear, Dieselsite.com coolant filter, SkyJacker dual steering stabilizer, Firestone Ride Rite airbags w/onboard compressor, Kleinn Train Horns, Bilsteins all the way around, Recon LED's in the back, Programmed with the SuperChips 1805 Tuner always set on Tow Safe for a little extra get up and go.
30' Cardinal 30TS 5th wheel. The weekend home away from home.
"The early bird may get the worm, but the second mouse gets the cheese."
overfly is offline
post #5 of 8 (permalink) Old 09-17-2006, 08:26 PM
FamilyRide's Avatar
FYI, even when there was 2 recalls for mine, only one showed up on the Ford site. OASIS showed all of them.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #6 of 8 (permalink) Old 09-17-2006, 09:14 PM
so where do you find out about the oasis report ?
2005 true blue f350 extendacab long bed with sport package and 18 inch wheels mrbp exhaust and ID tunes econo,street and tow aggresive , zoodad and true flow filter
1965 fastback mustang n/a low 9 second race car
1994 vintage 28 foot enclosed trailer
2005TrueBlueF350 is offline
post #7 of 8 (permalink) Old 09-17-2006, 09:23 PM
Take a look at the Dieselmann's page. He has a section on Powerstroke Bulletins, where you can find recalls and TSB's. There is a ton of information on this site.
http://www.intellidog.com/dieselmann/home.html
2004 F-350 XLT,4X4,SC,Short Bed,FX4,6.0 PSD,Torqshift,3.73 LS,Red,Medium Flint Captains Chairs,Camper @ Snowplow Packages,12.5K Hitch Receiver,TT Pwr Mirrors Roof Clearance Lights,
Engine assembled 12/18/03
Truck built 12/21/03,
MBRP 4 inch turbo back straight pipe
ARP Head Studs
Head Gaskets
Oil Cooler
BPD EGR Cooler
BPD 48 volt FICM
Sinister Coolant Filter
Updated Turbo Feed & Drain
Blue Spring Mod
RJBain is offline
post #8 of 8 (permalink) Old 09-17-2006, 09:23 PM
Some websites such as flat rate tech and diesel garage etc have sections were you can post your vin number requesting a Oasis report.
You can also ask your service writer at the dealership to give you a copy of the Oasis report. I get one from my service dept periodically when I hear of things or when I have had warranty work done (rear diff cover leak x2, fuel guage sending unit, flashes) so I can see what was actually submitted to FOMOCO and compare that to my invoice and for my own records.
Mntsnow
Mntsnow is offline
