2004 6.0L Stalling/Dies Randomly - Diesel Forum - TheDieselStop.com
post #1 of 21 (permalink) Old 04-18-2017, 10:00 PM Thread Starter
Hello Diesel Friends,
I have a problem that seems sort of specific and after searching several other threads and forums I haven't come up with an exact match. I have also watched countless videos of Diesel Tech Ron.
Truck: 2004 F350 6.0
EGR DELETE
Replaced Oil Cooler
ARP Head Studs
New Injectors
New Glow Plugs
Western V-Plow
Aftermarket Exhaust/Air Intake
170,000 Miles
All of the above except the intake, exhaust, and egr delete was done by me about 2 years ago. Truck has ran fine until now.
Current Situation:
I have a landscaping business and this truck is used to pull a 16' trailer and lawn mowers. About a week ago I was pulling with it (rare occasion, my employees use it most of the time) and it stalled on a very VERY slight incline. The truck just died and I pulled over. I tried to crank but no start, I got out, lifted the hood, glanced around, googled my problem, found nothing specific, tried to start it up and it fired. I went on about my business driving it another 10-15 miles that day with no problems. The next day my employees had it die on them in the middle of the day after using it from 8am to about 1pm. I was running a skid steer so my business partner went out and after about 10 minutes it started back up. They got about 3 miles down the road and it happened again. This time they unplugged the batteries for about a minute, plugged them back in and it fired right up. Another 5 miles down the road it happened a 3rd time with the same battery unplug/replug results. They got it back to the our shop. I drove it home that evening and gunned it all the way home, ran like a scalded dog, no problems. The next day they took it out again and got about 10 miles from our shop and it died. We got it back to the shop and haven't used it to pull since. However, I have driven it over 200 miles since then without a single hiccup. I've got my scan gauge 2 in it and I'm trying to recreate the problem. Today I put the 16' trailer on it empty and pulled it uphill hard, drove it around town and tried to give it a lot of work and it never stalled. The only difference now is I didn't have the 2 mowers on the trailer. I'm stumped.
Current Scanguage Readings -
Key On Engine Off:
IPR - 14.8%
SYN - 0
FMP - 48.5v
ICP - 55 ***(I think this is weird, Diesel Tech Ron said it should be between 0-15) With the ICP unplugged it obviously reads 0
Pulling the trailer at 45mph at 2500 RPM's:
IPR - 63.6 %
SYN - 1
FMP - 49.0v
ICP - 2603
Any suggestions? Thank you all for taking the time to read all of that!
NightcrawlerF350 is offline
post #2 of 21 (permalink) Old 04-19-2017, 01:54 PM
Phil G.'s Avatar
I'm wondering about fuel starvation, dirty filters, weak pump. I would suggest you get a fuel pressure gauge on it while you are driving it before tearing into anything on the engine.
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4. Viper Alarm/RS, WD pillar Guages,AutoEnginuity, 100gal polished alum fuel tank.
All Sold: 99.5, early03 , 2004 - all were 172" wb 4x4 lariat's.
My Worklog:
Phil G. is offline
post #3 of 21 (permalink) Old 04-19-2017, 05:07 PM Thread Starter
We are trying to get ahold of a fuel pressure tester that will fit my truck. In the meantime we were able to get the truck to stall out today. The readings on the scan Guage are as follows:
IPR - 84.7%
ICP - 229
Ficm - 48.5v
Sync - 1
These readings are when we were trying to restart the truck during crank. If we let the truck set for around 5 minutes it would fire back up like normal. This happened 3 times today while we were out testing it. I'm sort of leaning away from the fuel or fuel filters because the thing literally shuts off like you turned off the key, no sputter or warning signs like it's running out of fuel.
post #4 of 21 (permalink) Old 04-19-2017, 06:27 PM
Phil G.'s Avatar
Ya, your IPR is wide open on those numbers you just posted... sure seems to point to HP oil system. Next step would be an air test, don't forget to command the IPR closed or turn it off with Bat+ for short periods of time.
My Worklog:
Phil G. is offline
post #5 of 21 (permalink) Old 04-19-2017, 06:48 PM Thread Starter
Good news, the scanguage gave some codes
P0069
P006A
P2285
P2623
post #6 of 21 (permalink) Old 04-19-2017, 06:58 PM
late or early 04? (where is the ICP located)
My bet is on a failing HPOP, but a short in the ICP sensor or wiring can also make it stall/shutdown while running.
Mark
bismic is online now
post #7 of 21 (permalink) Old 04-19-2017, 07:04 PM
P0069: MAP Barometric Pressure Correlation. MAP, BARO, EBP, ICP, APP (throttle pedal), EGR, and MAF are all tied into the same circuit (vreference). Post your MAP and Baro readings at KOEO.
P006a: MAF sensor code - part of Inferred EBP strategy. Will throw a wrench light. Because of this, I bet you have an early 04 w/ the ICP behind the turbo.
P2285: ICP Sensor - Circuit Low. Visually inspect the ICP sensor harness and connector for damage, corrosion, or incorrect routing. This is what you get when you disconnect the ICP, so that may be it if you try to start w/ it disconnected.
P2623: Stuck turbo, MAP sensor, MAP hose plugged or leaking, CAC hose disconnected or leaking, intake leaks, exhaust restriction, exhaust leaks, EBP sensor or EBP tube plugged, or bad VGT solenoid. This code is set when MGP does not go over 15kPa or 2.2 psi when the following conditions are met: rpm must be over 2800; VFDES above 35; and EGRVP above 0.10. All of these conditions must be met for 5 seconds for the code to be set. This code can also be set if there is ANY condition that would produce low power.
Mark
post #8 of 21 (permalink) Old 04-19-2017, 07:25 PM Thread Starter
Its a late build '04. The ICP code is probably because I unplugged it to see if it would fix my issue. The P0069 code has been pulled before, its not new along with the current problem.
post #9 of 21 (permalink) Old 04-19-2017, 07:28 PM
MAP, Baro, and EBP readings at KOEO?
Mark
post #10 of 21 (permalink) Old 04-19-2017, 08:59 PM Thread Starter
how do you find BARO value? Never looked at that. Thanks
post #11 of 21 (permalink) Old 04-19-2017, 09:04 PM
Barometric Pressure (PSI)
TXD: 07E0221442
RXF: 046285140642
RXD: 3010
MTH: 001D0050000
NAM: BAR
Mark
post #12 of 21 (permalink) Old 04-20-2017, 08:21 PM
STMPDUST's Avatar
Did you replace the fuel filter UNDER the truck, i had stalling issues before and it was that little bugger right there.
2015 KR Dually CC 4X4 Bronze Fire HC
2011 KR Dually CC 4X4 Royal Red
2005 Eddie Bauer Excursion 4X4 ,White
STMPDUST is offline
post #13 of 21 (permalink) Old 04-20-2017, 09:13 PM Thread Starter
Did it shut off with no warning signs or did it sputter and stuff first in this situation?
post #14 of 21 (permalink) Old 04-20-2017, 09:20 PM Thread Starter
I have been slammed with work this week and I didn't have a chance to get the BARO code put on my scanguage II however, I did want to check my EBP. The EBP used to give me a reading that was proper (about 3 years ago was the last time I checked it. Since my motor was rebuilt I had used an SCT excalibrator that came with the truck to make sure it was put back into stock mode. I'm not sure if it was in stock mode before or not, when I bought it from the guy he just had the tuner and gave it to me with the truck. Any idea why I would no longer get an EBT reading. I know the scan gauge is programmed correctly because I can hook it up to my other 6.0 and it'll read EBT correctly. When its plugged into the truck I'm having problems with there is no number whatsoever beside EBP, everything else I have programmed in is reading normally. I'll get back to you on my BARO. Thanks everyone.
post #15 of 21 (permalink) Old 04-20-2017, 09:41 PM
If you have an early 04 engine (ICP behind turbo), AND the PCM has been reflashed, then you won't get an EBP reading because a TSB eliminated that in 03 and early 04 engines (it just uses an inferred EBP value).
Mark
