2004 Automatic Tranny Tow Haul Light Blinks - Diesel Forum - TheDieselStop.com
Old 11-17-2006, 01:10 PM   #1 (permalink)
My Tow haul light started to blink the other day while towing my 20' enclosed trailer. Everything still works fine other than the tranny temp guage. The next day I used the truck again and everything was working fine for the first 5 miles then the tranny temp guage stpped working and the tow haul light started blinking again. Anyone have this happen?
465stroker is offline
Old 11-17-2006, 01:14 PM   #2 (permalink)
desertwheeler's Avatar
Re: 2004 Automatic Tranny Tow Haul Light Blinks
On my 97 i know that means the trany is throwing a code. If everythign still works fine just the guage that may be the problem. Id say have someone read the codes.
08 F250 CC SB 4x4 New baby.
03 F250 SC LB 4x4 sold
In SO-CAL?
Check out Southern California Powerstrokes.(SOCAPS).
desertwheeler is offline
Old 11-17-2006, 06:04 PM   #3 (permalink)
I'd take it to a dealer if you still have warranty. My T/H light started flashing 15 or 20 miles before the transmission croaked.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
Old 11-17-2006, 07:57 PM   #4 (permalink)
JW350's Avatar
My Photos: (29)
My truck was just in the shop for the same exact problem. Tech replaced the temp sensor in the trans and the trans wiring harness. I was at 36,700 miles - cost me $550. [img]/ubbthreads/images/graemlins/mad.gif[/img]
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, Fox Shox, 37x13.5x17 Toyo Open Country MT on Weld Evo Velociti XT, 4.88 Gears, MagnaFlow Exhaust, AMP Research PowerStep, Auto Meter Cobalt Gauges (EGT Boost Trans), ScanGaugeII, Firestone Air Bags/Compressor/Tank, BulletProofDiesel EGR Cooler, Valvoline lubricants, Final Charge Global ELC, DieselSite Coolant Filter
JW350 is offline
Old 11-17-2006, 08:05 PM   #5 (permalink)
If your T/H light starts flashing when your temp gauge is erratic, most likely will need temp sensor. This is a fairly common concern on these things, especially with higher mileage. Sensor costs about $78 bucks, plus fluid, filter, (while your in there), and labor.
djshum is offline
Old 11-21-2006, 07:58 AM   #6 (permalink)
Dealer just called to let me know it was the temp sensor needing replaced. $460 estimated cost..
Thnaks for all your help!
