2005 6.0 Powerstroke :: Coolant Flush Problems - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 03-05-2011, 05:19 PM Thread Starter
kmaccullough's Avatar
I recently bought this truck and I have no records of the maintenance so I've decided to just go through everything and replace all of the fluids and filters myself. Today I'm on the coolant flush but I've ran into a puzzling problem. Unfortunately for me, the dealerships are closed so I can't take it down there.
I followed this guys procedures on powerstrokehelp.com:
Everything went fine, but now that I'm filling up the system it has only taken 2.5 gallons of coolant and I haven't even added the distilled water. The system holds approx. 6 gallons so I'm wondering why I'm not even half way and the bottle says it's filled.
When I emptied the old coolant into some gallon jugs from the pan, it only filled up 2.5 gallons as well.
I'm sure some coolant/water stays in the system for the flushes, but how much? No way it's 3.5 gallons right?
2005 F-250 Lariat Crew Cab 6.0L Diesel
1973 K5 Blazer 350
kmaccullough is offline
post #2 of 19 (permalink) Old 03-05-2011, 05:51 PM
Did you drain the block as well?
2016 F350 Platinum (Build date 1/2016)
6.7L, Ingot Silver
Had:
2006 F250 King Ranch FX4 - (Build date Sept. 2005)
6.0L (Engine Build date Sept. 21 2005)
Dark Copper w/ Beige accent
ralderman is offline
post #3 of 19 (permalink) Old 03-05-2011, 06:38 PM
paintingman's Avatar
There are plugs just below the exhaust manifold on each side you need to remove them to drain the block
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
post #4 of 19 (permalink) Old 03-05-2011, 07:10 PM Thread Starter
Thanks for the speedy replies guys.
So you're saying the block holds the rest of the coolant/di water? After flushing the system a few times, it looked like the coolant was 99% gone and just distilled water sitting in there. The entire system would've been flushed whether or not I drained the block as well.
If the block and the rest of the system hold a few gallons, there was already that much distilled water sitting in there that didn't drain from radiator fitting.
Does this sound right?
1973 K5 Blazer 350
post #5 of 19 (permalink) Old 03-05-2011, 09:37 PM
The clean water would be Ok if your using strait coolant. if your using 50/50 premix you may want to drain it all
ATS Intercooler
Aluminum degas tank
post #6 of 19 (permalink) Old 03-05-2011, 11:09 PM Thread Starter
No this is the Motorcraft Premium Gold shown in the video, and it's straight coolant unmixed.
Thanks.
1973 K5 Blazer 350
post #7 of 19 (permalink) Old 03-06-2011, 12:27 AM
Staaaay away from the crap Ford Gold Collant! The silicates in the coolant is what causes oil coolers to plug ruining your EGR cooler! Do some research and you'll find a lot of guys using a ELC (Delo) extended life coolant. Flush with 'Restore' and 'Restore plus'(cummings product) or 'VC-9' (ford product). You need to do a serious flush to get rid of ALL the ford gold coolant. If you have a couple hundred bucks do yourself and your PS a huuuge favor and get a coolant filter. Dieselsite.com has them at a good price! The Delo ELC is not that easy to find but with a little hunting in your home town you'll find some. Let me know if you can't find any further info on this....
James
CHPJames is offline
post #8 of 19 (permalink) Old 03-06-2011, 05:36 AM
The total system coolant capacity is 27.5 quarts, and yes - it will hold a lOT, so flushing w/ distilled water is very wise.
Mark
bismic is offline
post #9 of 19 (permalink) Old 03-06-2011, 06:21 AM
Band_Member's Avatar
My Photos: (64)
I've ordered 30 gallons of distilled water (for less than a buck a gallon) for when I do my flush. I don't have county water, I have a well with 2 sediment and a carbon filter and with all the minerals in the water, particularly lime scale, I don't want them in my engine block, water pump, radiator, and cooling system. But that's just me. To each his own.
Oh, yeah, and I'm not putting the gold c**p back in. Delo or Rotella ELC
2005 F250 XLT SC, LB
6.0 Torqueshift 3.73LS 4x4 T/C
Trk Bld: 02/05/05 KY
Eng Bld: 02/03/05 Indianapolis
2825 Hrs +/-, 101K Miles - No Major Probs other than brakes
DC Power 185 Alternator
ZOODAD, SEIC,
Atlas 40 FICM @ 90K
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Duratrac's
Centramatics
Bodiak Front Receiver
SG2
Coolant Filter
HFCM Plug Upgrade
FP Gauge
Zerex Red ELC
Band_Member is offline
post #10 of 19 (permalink) Old 03-06-2011, 01:28 PM
You may not want to use the motorcraft the guy's have been finding out that the silica over time turns into gel and clogs the oil cooler. the best flush is the restore then use a silica free coolant everyone has a brand they like or say it's the best as long as it's ELC silica free i like this one AMSOIL Propylene Glycol Antifreeze and Engine Coolant - ANT
ATS Intercooler
Aluminum degas tank
post #11 of 19 (permalink) Old 03-06-2011, 02:52 PM
mwilbur516's Avatar
If you use the Ford Gold coolant, go ahead and order a new oil cooler, Egr cooler, head studs and new gaskets. Or you could use the ELC and add the coolant filter.
06 F250 XL, FX4, Upfitters, TBC, 15% window tint, 3.73's, Muffler delete, Cat delete, Fumoto valve, High idle mod, Zoodad mod, Harpoon mod, CCV mod, ARP studs, SCT Livewire w/ Looney Wild DD Tune, Dieselsite.com coolant filter, Glow Shift Fuel Pressure Gauge, Ford Blue spring upgrade, 6.4l Banjo Bolts, Upgraded turbo boots, Upgraded HFCM drain plug, Quick Tricks 58 volt FICM, S&B CAI, Monitoring EOT, ECT, EGT, IAT, Voltage and RPM
Horsepower is like a gun; You may not always need it, but it's nice to know its there
mwilbur516 is offline
post #12 of 19 (permalink) Old 03-06-2011, 04:29 PM
I just ordered a case (6 gals) of Shell Rotella ELC concentrate coolant from Amazon.com An Ace hardware in NY sells it through them. With delivery to NM it is $ 140.00 or about 24.00 a gallon.
I only need 4 gals but they only sell it by the case and it can not be found locally so I will have 2 extra gallons in reserve
2004 F250 Harley Davidson Trim Crew Cab Long Bed
HFCM Water Separator Drain Plug Upgrade
Dieselsite Coolant Filter
Sinister EGR
New (6-16) Ford OEM oil cooler
Shell Rotella ELC coolant
Blue Spring Upgrade
Always Shell Rotella T6 syn 5W40
Edge Insight CTS
2007 Fleetwood Nitrous M-260FS Toy Hauler
Captrick is offline
post #13 of 19 (permalink) Old 03-06-2011, 06:08 PM Thread Starter
Sweet! Thanks for all of the info guys.
I tested out the coolant today and it was dead center. So looks like I'm good!
I've done some research on the motorcraft premium gold, but I've also read some stuff that says the silicates aren't enough of a problem to even worry about.
This 6.0 has 116xxx on it right now, so I'm currently saving for a new egr cooler from bulletproof diesel, plus the install. That's not something I want to do myself, so I'm gonna pay the money to have it done right. At that point I will switch to the coolant everyone is recommending. But for now I'm sure this ford stuff with be fine.
1973 K5 Blazer 350
post #14 of 19 (permalink) Old 03-06-2011, 07:08 PM
jeffws's Avatar
X2
05 F 250 CC PSD FX4
BPD EGR Cooler
DC Power 185 amp
Edge Insight CTS w/ Fuel Pressure, EGT and Turbo Timer
Blue Spring Upgrade
High Idle Mod
Mag-Hytec 6 Quart Diff Cover
Bilstein Shocks & Dual Stabilizer
285 75 17 Toyo's
Airlift Air Bags
jeffws is offline
post #15 of 19 (permalink) Old 06-16-2014, 10:50 AM
I have a 2005 F350 6.0 in top condition.I want to do a flush.How many gallons or quarts of coolant will I need to replace? Please reply.....GruntAshua
GruntAshua is offline
