2005 6.0L Turbo Issues - Diesel Forum - TheDieselStop.com
Old 11-28-2012, 04:18 PM   #1 (permalink)
Supporting Member
ghostrider01t's Avatar
I recently began to have issues with my F350. When in idle, the RPM's would jump, and then decrease to almost shutting down. Also, at one point, while still running, I could not get the truck to accelerate through an intersection, at only coasting. The engine is under warranty, and the Ford place said it was my turbo. But to determine if the problem is covered under warranty, they are required to disassemble the turbo. If it's not covered, then I am responsible for $2,000.00 in cleaning carbon parts/repairs. If they pull it apart and find damage to the blades, or any other damage then it will be covered under the warranty.If someone else takes the turbo apart to clean and replace any parts, will this void the warranty? And, is there an easy way to clean carbon from a turbo?
ghostrider01t is offline   Reply With Quote
Old 11-28-2012, 04:40 PM   #2 (permalink)
Xx_Razgriz_xX's Avatar
Originally Posted by ghostrider01t View Post
...And, is there an easy way to clean carbon from a turbo?
You have the right mindset to be weary of the 'Stealership'
They hate Warranting these things and will do anything not to.
As far as cleaning the turbo, there are plenty of write ups on here as well as dozens of YouTube videos that will show you how to do it yourself. I wouldn't say it's easy, just more or less time consuming, but it's doable if you are careful and take your time, and will save you money if you can do it yourself.
http://www.youtube.com/watch?v=fifAzKKHq1k
SOLD
2003 Ford Excursion
6.0L PSD with 224,XXX+ Miles
Scangauge II w/ BlendMount Kit
Sinister Coolant Filter
+40hp FICM tune / No turbo-lag
MBRP 4" Turbo-Back straight piped
New HPOP 205k, FICM referb @215k, everything else original & stock
Old Faithful.
Xx_Razgriz_xX is offline   Reply With Quote
Old 11-29-2012, 01:07 AM   #3 (permalink)
05_HARLEY_F250's Avatar
But would that void the warranty since the dealership didn't pull and inspect it first. Could they come back and say, "who ever tampered with this turbo broke it"?
Sent from my iPhone using AutoGuide.com App
Replaced stock w/stock
Radiator
EGR cooler
Head gaskets
Harley Davidson windshield
Replaced w/or added, upgraded, modded or converted.
Scangauge II
RECON Big Rig Ice running board lights, interior LED light conversion.
RECON smoke LED tail lights, third brake light, mirror lights, fire & ice tailgate strip.
ARP studs
Garrett powermax turbo
Metal CAC tube, Turbo oil supply and drain conversion
Blue spring
Fuel/water separator drain plug
Goodyear Wrangler Duratrac 275/65R20
Drilled/slotted rotors w/ceramic pads
IPR Generation 2 EGR delete.
IPR High flow coolant filtration system.
JVC KW-NT700
Coming Soon!
Rear mounted under bumper off road lights for hooking up & setting up trailer.
Frame mounted air compressor w/ 2gal. Reserve.
05_HARLEY_F250 is offline   Reply With Quote
Old 11-29-2012, 02:09 AM   #4 (permalink)
Feedback Score: 2 reviews
Did the wrench light come on. You need a get gauges, the Edge Insight CTS will read what the turbo is doing. VGT should read between 15 to 85%
Check your HOT side of the turbo on the boots use a mirror and a light it comes apart where you can't see it.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline   Reply With Quote
Old 11-30-2012, 11:12 AM   #5 (permalink)
Supporting Member
P0299 lack of power and turbo sticking on a 6.0 Powerstroke F250 diesel - YouTube
2 stroker
I have an Edge Insight installed on my rig, and no, the "Wrench lite" has not come on. No "warning" lights are showing anywhere. And I am weary of changing out parts for fear of voiding the warranty. Since no one has actually looked inside the turbo, I realize there is no way to determine if the problem is carbon, or the turbo itself.
Old 11-30-2012, 12:31 PM   #6 (permalink)
The symptoms you describe don't sound like a turbo issue, it sounds more like an icp sensor issue (poor connection/biased sensor). But, if it is indeed a turbo issue and you have the Ford ESP coverage, there shouldn't be any issues with getting it covered by your warranty...and chances are, if the vanes or unison ring will have enough wear to warrant turbo replacement, as vanes are not a serviceable item. What codes were stored in pcm? With the issues you describe, I would suspect a code to be stored.
djshum is offline   Reply With Quote
Old 11-30-2012, 01:03 PM   #7 (permalink)
OT
OT's Avatar
ghost...Way u put it sounds like turbo repairs "limited" as to what may/maynot be covered. Is that way its worded in YOUR warr. paperwork? Were u told what diag. done that indicated teardown needed?
Could be expensive gamble/maybe not, but I'd think twice about DIY repair on turbo under warr. Yeah, i see your concern. FWIW..Wierd how DTCs work. My t. overboosted, bad h.g. & no CEL or DTC was set. Good luck on outcome.
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline   Reply With Quote
