2005 6.0l won't start. - Diesel Forum - TheDieselStop.com
Old 07-19-2009, 06:05 PM   #1 (permalink)
As the title states.
It's been sitting about a week, tried to start it today and no go. Turns over like crazy, but won't even try to fire. Has occasionally been a bit slow to start over the last while, nothing too bad, but a bit more cranking than I before, or so it seemed. Of course, it's just off warranty, 163,000km. Figures.
Anyway, from searching, it seems the most common problems for the 05 6.0 are the stc fitting and the ficm. Should there be any codes appear from not starting, or would codes only show up once it was running?
Trying to figure it out if at all possible due to the off warranty thing, can't afford to fix anything too major.
altaford is offline
Old 07-19-2009, 06:38 PM   #2 (permalink)
You should probably rig up a pressure gauge to install where the ICP is located. You need 500 psig to start. If you do not have 500 psig while cranking, then it is in your HPO system and very likely the HPOP STC fitting.
Have you pulled the secondary fuel filter out of the filter housing, emptied the bowl, and cranked to verify that the HFCM is pumping?
Mark
bismic is online now
Old 07-19-2009, 06:46 PM   #3 (permalink)
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
Oil rail plug, when it fails the truck will have long crank and no start
Replace w/ part# w302195
2000 F-350 7.3 PS ,4R100 Lariat Dually
http://i829.photobucket.com/albums/z...DSC02732-1.jpg
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:http://photobucket.com/2000_F350
PowerstrokeConverters is offline
Old 07-21-2009, 09:45 AM   #4 (permalink)
Well, no codes are showing up right now. Tried it with the small engine mounted fuel filter removed, wondering how much flow should be coming from the HFCM. There is definitely flow, but I don't really know how fast it should be coming.
On this 2005 with the ICP under the HPOP cover, where can I hook up a guage to check my oil pressure?
Thanks.
altaford is offline
Old 07-21-2009, 09:25 PM   #5 (permalink)
Thanks.
Your ICP is on the passenger side valve cover.
Mark
