2005 F-250 - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 05-07-2005, 11:35 PM Thread Starter
2005 F-250
I'm looking to purchase a 2005 F-250 w/ the 6.0. I've heard alot of good and bad about the engine. I'm also concerned about the fuel economy. I'll be towing a 7000 lb. boat and would like to know what kind of economy you are experiencing. What rearend should I get for towing and max fuel economy? Also, this is my first diesel engine, so all of your thoughts and advice are appreciated.
Thanks,
Zukeman is offline
post #2 of 4 (permalink) Old 05-07-2005, 11:48 PM
Re: 2005 F-250
I have an 05 towing an 11,000 pound horse trailer. Economy with trailer - 12mpg. Without 16mpg city, 19+ (as high as 22 the other day)hwy. I use a superchip tuner set at tow safe all the time - great shifting, torque etc. I have the 3.73 rear end and it pulls just fine. I will be getting the mag hytek tranny and rear end pan to keep temps as low as possible.
05 F250 6.0L Lariat, crewcab, SB, 4WD, auto, 3.73 SuperChip, stock filter, no cat, Accufab intake elbow, Timbren suspension
denderlein is offline
post #3 of 4 (permalink) Old 05-08-2005, 11:29 AM
Re: 2005 F-250
Take a long look at the 250 vs. 350. The 350 costs, depending on the details, around $1,000 more than the 250, i.e., less than 3% more. The two vehicles are almost identical, i.e., if similarly equipped they both ride the same, list the same options, etc., except that the 350 is rated for higher loads.
In some areas higher taxes and fees on the 350 influence the choice.
Clearly either model will pull your boat.
I purchased new a 2000 F-250, and too frequently wished for a 350. I now think of the 250 as a 350 crippled for marketing purposes.
Bob
Silver '05 F350 Lariat CC PSD, auto, SB, 2WD, SRW, 3.73, Tuff liner, Retrax bed cover
DigitalDriver is offline
post #4 of 4 (permalink) Old 05-10-2005, 09:46 AM
Re: 2005 F-250
The 05 f250's have a MUCH higher load cap than the old f350's.My bed capacity is 3100 lbs.My 250 will do everything i need it to do.
2005 f250 cc Lb 2wd PSD
rocky7184 is offline
