2005 F-250 Transmission Service - Diesel Forum - TheDieselStop.com
Old 10-09-2009, 04:08 PM   #1 (permalink)
2005 F-250, 6.0 Lariat. Now at 60,000 miles.
In reference to transmission service,
Dealer says flush it and change in-line filter - about $ 290.00
AAmco says DO NOT flush it, but drop pan and change filter - about $ 150.00, says flushing is not recommended.
Money matters, but doing the right thing for this machine is my goal.
What do you people think?
Thanks.
Highwinds is offline
Old 10-09-2009, 04:50 PM   #2 (permalink)
AAmco
I am not a transmission expert. But I have been around auto/truck maintenance for 40 years. I have not had a good experience with flushing, a few years ago I had company car transmission fail after tranny flushing. Maybe not related, but on my vehicles I have been dropping/cleaning pans, changing filters, CLEANING magnets, draining torque converters (when you can) and I haven't had a tranny failure since 1973 (I was 17 and very hard on trannys). I plan on servicing the tranny in my 2004 6.0 next week.........
hparm Raleigh NC.......2011 F350 6.7 CC LWB Lariat, 4x4, 20" Michelins, 3.55 EL rear, FX4, Factory Reese 25K 5th Wheel, White with Adobe, Tinted Windows, Line X Bedliner............
SOLD
2004 (early) F350 Lariat 6.0 Auto, FX4, 78,000 miles, CC, DRW 4x4, Tinted windows,,.......Amsoil in Motor, Trans, power steering, rear end....Dieselsite coolant filter.................White
2011 Jeep Wrangler Unlimited
2008 3612 Raptor,
1997 FLSTF
hparm is offline
Old 10-09-2009, 06:10 PM   #3 (permalink)
69cj's Avatar
Torque shift tranny neeeds to be flushed with a flushing machine that heats the fluid. TS tranny has an internal thermostat that doesn't open til 164 degrees. Ford also states to flush tranny at 30,000 mile intervals. Not demeaning anyone but Aamco is one of the last sources I would listen to when it comes to the TS tranny. I don't trust them with a C6. Also, whoever flushes it must use Mercon SP fluid. If they say they have an equivelant equal, walk, no run away as fast as you can.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 10-09-2009, 08:27 PM   #4 (permalink)
Had mine flushed at 30k miles. Now at 55k. All is well. Flushing is a good thing as long as you do it at the proper intervals.
Mark
bismic is offline
Old 10-10-2009, 12:01 AM   #5 (permalink)
Banned
I haven't seen any "great" advice....
Using a "flush" machine to perform a fluid exhange is going to be OK as long as no "flush chemical" is used.... It is not spec'd in the WSM... I am always fearful that enough of the active solvent will remain in the system to offer future concerns...
FWIW.... any service that includes the word "flush" should have the word "wallet" included in the mantra....
Transmission fluid service should be performed in accordance with the factory workshop manual recommendations.... if your shop doesn't have access to this information..... what can I say?
GrampyJim is offline
Old 10-10-2009, 01:33 AM   #6 (permalink)
I have always followed this, hopefully Grampy can yea or nay it:
File Type: pdf s5o~us~en~file=s5o71031.pdf~gen~ref.pdf (126.7 KB, 174 views)
File Type: pdf s5o~us~en~file=s5o71034.pdf~gen~ref.pdf (109.2 KB, 148 views)
jasonmt is offline
Old 10-10-2009, 04:48 AM   #7 (permalink)
hazard05's Avatar
fwiw, i did mine at 60k a few weeks ago, i took and oil sample, took it out got the tranny hot, drained the fluid out as much as i could. pulled the pan, cleaned the magnet, changed the screen and inline filter and re filled, i bought 10 quarts and glad i did, most say you will only use 7-8, i used all 10 and the level is perfect, my oil analysis was perfect. ill do it again in another 15k miles, thats what the lab tech at CATERPILLAR suggested (where i do my samples) and i trust him, hope this helps ya man.
Thanks,
Adam
2006 F-250 6.0L CCSB Lariat 4x4 w/towing package, Chrome package, Billet grille, Silverline 4" turbo back exhaust no cat no muffler! Upfitter switches w/high idle mod Edge Insight monitor w/EGT probe DeeZee bed mat, Stampede chrome bug shield. other than that its bone stock! Hopefully more to come!
"Run Hard, Dream Big"
hazard05 is offline
Old 10-10-2009, 11:48 AM   #8 (permalink)
Thanks everybody!
Old 10-10-2009, 04:13 PM   #9 (permalink)
GrampyJim....
What does "Factory Workshop Manual" recommend for a 2006 6.0 Automatic with Torqueshift? Flush or no flush? Hard to get an answer from the Service Rep.
Thanks in advance.
06 F-350 PSD Auto DRW 4x2 SB 4.3
DieselSite Coolant Filter
Edge CS gauge with EGT Probe
Blue spring installed
Reese Class V hitch with extension
05 Lance Max 881 Camper, Happijac tiedown system with Torq-Lift Fastguns
Circle J Outback Plus 2 horse trailer
Registered Appendix quarter horse, Dun colored, ridden with an Australian saddle.
jvita is offline
Old 10-10-2009, 05:31 PM   #10 (permalink)
Originally Posted by jvita View Post
GrampyJim....
Thanks in advance.
Your owners manual states to EITHER drain the fluid and replace the external filter, OR flush w/ a heated flushing system, but to do one of these every 30k miles.
Mark
bismic is offline
Old 10-10-2009, 05:32 PM   #11 (permalink)
If flushing kills a tranny, I guess I have been just coasting down hill for the last few years. Tranny was flushed at 30K, 60K, 90K and 120K. Soon it will be flushed again at 150K. Just do what the owners manual says and use the right fluids, per the owners manual, and all will be OK.
PS. If you have not maintained the tranny and it has already started to slip and die, do not expect a flush to fix it.
Roy
2005 Limited, 6.0L PSD, 4X2, Mineral Gray, 3.73 LS. Excursion Build date 02-08-05 6.0L 2005MY Engine Build date 01-03-05 Huntsville, Ala.
2005 50th anniversary Thunderbird Red with all
options except hardtop.
Old Ride: 2003 Excursion 6.0 L March 2003 Build 73,000 with no significant issues.
RoyC is offline
Old 10-10-2009, 07:14 PM   #12 (permalink)
69cj's Avatar
Mark, I have gone thru both of my owners manuals and they, it, says "change automatic transmission fluid and external filter element" every 30,000 miles. Pretty ambiguous to me. That is in the 2005 manuals.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 10-10-2009, 09:01 PM   #13 (permalink)
My owners manual simply says to "Change automatic transmission fluid and external filter element" No mention of flush. Agrees with 69cj above.
jvita is offline
Old 10-11-2009, 12:01 AM   #14 (permalink)
The page number may vary slightly with model year, but look on (or around) page 50 of your Diesel Supplement. It states that flushing is a viable way to service your fluid changes.
Mark
bismic is offline
Old 10-11-2009, 02:57 PM   #15 (permalink)
Thanks for the tip, but I just went through every page of the supplement and it does not mention flushing anywhere.
jvita is offline
