2005 F350 4x4 switch on dash no workie - Diesel Forum - TheDieselStop.com
Old 11-11-2009, 07:13 PM   #1 (permalink)
any ideas on this?
on my 2005 F350, my 4x4 switch on the dash turns the 4x4 light on on the dash, but won't switch it into 4wd. I can hear it clunk, but it doesn't go into 4wd. I have to get out and manually turn the hubs to make it work.
Is this a fuse? a vacuum line? both?
help......
cthrasher is offline
Old 11-11-2009, 08:08 PM   #2 (permalink)
Supporting Member
my03psd's Avatar
Vacuum leak, or bad vac. pump.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 11-12-2009, 12:53 AM   #3 (permalink)
I was told that the same vacuum modulator for the 4x4 shift actuator is the same one that controls the heater blendor functions. My heater functions work fine though.????
Old 11-12-2009, 06:06 AM   #4 (permalink)
Check to see if there is power to the fuse in the cab. If not it is the relay on the firewall.
durantdiesel is offline
Old 11-12-2009, 01:35 PM   #5 (permalink)
ArchitectandBuilder's Avatar
If you have your heater on with either the dash vents or floor vents, and then turn on the 4x4 switch, does it stay the same, or does it change it to your defrost vents?
If it changes your air flow to defrost, then it's a leak or pump issue.
Barrett
Mine: 2003.25 F-350 Lariat CC, SRW,8' bed, 6.0, Torqshift, Toreador Red, Tan Leather, Trailer Tow, Rhino-Liner, Dee-Zee Platinum Box, Adjustable Pedals, Heated Seats, 6 Disk Changer, DVD, 04 Keypad, AIC, 20% Tint, Escort 8500 X-50, Magellan Meridian Color Gps, BFG 285r17 KM2’s. DPPI Dual SS Turbo Back Exhaust,"X" Springs,Issopro EV Pyro,Trans,Boost,Oil Temp, Water Temp, Volt Meter, Air Press., Viair 550C AC, 26" & 29" Hadleys, 2006 Front End, Chrome Tow Hooks, Warn 16.5ti, Billet Cummins Killer Badges, Int. VT-365 Badges.
Diesel_Mom's: (Redhead): Goodbye 2001 EX, Thanks for 4 years. Brand Spanky New 2005 Eddie Bauer Excursion, DVD, Toreador Red</font> , 6.0L Powerstroke, all options including (3) children, (1) 95# Golden Retriever, Goodyear Wrangler 285 MTRs.
ArchitectandBuilder is offline
Old 11-12-2009, 02:56 PM   #6 (permalink)
Barrett
When hitting the 4x4 switch on the dash, while the heater is blowing, the air flow through the vents remains the same.
Old 11-12-2009, 07:04 PM   #7 (permalink)
Supporting Member
my03psd's Avatar
I had a leak at the hub bearings and the 4 wheel drive wouldn't engage, but my heat always work the way it should. I was told that leak was small enough to mess the 4wd but not enough to mess w/ the vents.
my03psd is offline
Old 11-12-2009, 08:13 PM   #8 (permalink)
dikkstarr's Avatar
There are two o rings at each hub, ones a big yellow one on the back side inside the knuckle, and the other is a smaller black one on the locker side of the hub. I think one of these are leaking.
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline
Old 11-15-2009, 05:44 PM   #9 (permalink)
I traced all the vacuum lines and checked all the fuses, they all are good. I can hear the transfer case kicking in and out, but still nothing.
Have I mentioned I hate my 2005?
Old 11-15-2009, 07:12 PM   #10 (permalink)
Supporting Member
my03psd's Avatar
Use a smoke machine, like the one used for EVAP testings on gas cars, it's what we used on my truck and was very effective.
my03psd is offline
Old 11-15-2009, 07:32 PM   #11 (permalink)
Manually turn the hubs to make it work? So it works then? What happens if you leave the hubs in Lock position? Can you take the 4x4 in and out by using the switch?
2005 DWL SB Crew 6.0 w/tow command, 4:10 rear end. FICM Repair @75k, (Gift from 7/200 coverage) ScanGauge II, Banks Ram air intake, Coolant Filter, Banks exhaust, ARP Bolts. The whole OASIS would never fit here!
Munfrobie is offline
Old 11-16-2009, 11:53 AM   #12 (permalink)
yes I can take it in and out, while using the switch, if the hubs are manually locked in. If the hubs are set to AUTO, the switch will not lock the hubs in.
Old 11-16-2009, 04:39 PM   #13 (permalink)
Supporting Member
my03psd's Avatar
Do you know anybody w/ an 05 to swap out the hublocks themselves?It really sounds like a vac. problem.I had a hard time finding my leak.That's why we went to the smoke machine.If they lock in and out no problem w/ the hublocks locked, but not in auto it's gotta be leaking somewhere.
my03psd is offline
Old 12-03-2009, 05:53 PM   #14 (permalink)
Hi I have a 2004 F350 Lariat and that is what you have to do with these years, is actually lock the hubs on and then turn it on inside the truck on the dash. The Ford dealer here told me just to leave my hubs locked after the first snow fall and just use my switch then unlock them in the Spring.
mssytasha is offline
Old 03-02-2010, 10:12 AM   #15 (permalink)
Hmmm - wouldn't that mean your front wheels and axle are engaged all the time then? What will that do to your mileage? or the front transfer case gears?
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
rcgreg is offline
