2005 torqshift autoTrans fluid capacity - Diesel Forum - TheDieselStop.com
Old 08-11-2006, 10:02 PM   #1 (permalink)
I had my f250 transmission filter and fluid changed yesterday. They added 10.5 qts. after draining the pan and changing filter. I checked it today and it appears they may have overfilled it. What is the fluid capacity not including the torque converter fluid- It wasn't drained
troys767 is offline
Old 08-11-2006, 11:24 PM   #2 (permalink)
hitecdan's Avatar
My Photos: (22)
Re: 2005 torqshift autoTrans fluid capacity
6 to 7 quarts if you just drain the pan. Another 1/2-quart changing the filter.
My html Version of the 6.0L Bible Now with 2005 Updates
$5 AIC
Born on date: Jan 20, 2003
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 4/15/2010)
The United States Constitution © 1791, All Right Reserved.
hitecdan is offline
Old 08-12-2006, 07:43 PM   #3 (permalink)
waylntat2's Avatar
what is the motorcraft trans filter # for the 2004 Tow/haul
2004 F250 SD XLT Fx4 Grey mett. Soft tanto cover, 6.0 PSD Towhaul/Water coolant Filter/custom pinstipes By twisted Image,Highvolts/42.000 miles 2/08
waylntat2 is offline
Old 08-13-2006, 09:04 AM   #4 (permalink)
Bear_Hunter's Avatar
My Photos: (9)
Make sure your truck is at operating temp and it is RUNNING when you check the trans fluid level or it will be incorrect.
TRUCK PICS Lifted by Truck-Toyz
JAKD 2007 Dark Stone Harley Davidson Edition Super Duty Custom Built By Trucktoyzperformance.com
Special Thanks to: Trucktoyzperformance, Autometer, Rize Industries, MBRP, Line-X of Friendswood TX, Accufab Racing, Painless Performance, Retrax, OilGuard, and DC Customs
Also brought to you by Critical Fight Gear & Suckerpunch Entertainment
Bear_Hunter is offline
Old 08-13-2006, 11:14 AM   #5 (permalink)
go to motorcraft.com & find the links for specs. on any veh you want.
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
