2006 F350 6.0 Injectors - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 03-07-2012, 10:11 AM Thread Starter
I have a '06 F350 with 6.0 liter diesel engine. Ford put a brand new engine in my truck at 90,000 miles. I now have 130,000 miles on truck and have had to put in at LEAST 6 injectors. I am religious about changing oil at 3000 miles and fuel filters every other oil change. I run ford recommended fuel conditioner in ever tank of diesel. I just cannot help but blow injectors out. What can i do to fix this??
clattermac is offline
post #2 of 6 (permalink) Old 03-07-2012, 10:21 AM
fordsforever73's Avatar
My Photos: (24)
Feedback Score: 2 reviews
Couple of things you need to check to start with.
1. Voltage check on the FICM (Fuel Injection Control Module)
2. Fuel pressure check.
I'm no pro, and I'm sure others will chime in. I believe the FICM has to be 48 volts or higher to work properly. There is an upgrade from dealer (Blue spring upgrade kit) that raises the fuel pressure and in turn, injectors work better...and last longer.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. FICM by Ed with Atlas 40 tune, DC Power 185 amp alternator, MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. +More.
fordsforever73 is offline
post #3 of 6 (permalink) Old 03-07-2012, 10:26 AM
My bet would be weak fuel pressure. The blue spring kit will fix that. Low fuel pressure at WOT will kill injectors. If your FICM was bad you would probably notice something with drivability.
Sent from my ADR6300
2005 F-350 SRW, Lariat, 156" WB, 4x4, auto, True Blue, 96k miles, stock.
Canyonero02 is offline
post #4 of 6 (permalink) Old 03-08-2012, 09:00 AM Thread Starter
I did just a little preliminary research about this upgrade, with the blue spring. It seems pretty simple, and compared to what ive spent so far on injectors, pretty cheap.
Is there any negative possible effects of doing the upgrade spring kit??
Thanks for your help
post #5 of 6 (permalink) Old 03-08-2012, 09:31 AM
dieselmac's Avatar
Absolutely none.
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #6 of 6 (permalink) Old 03-08-2012, 09:14 PM
Clattermac, I did my blue spring 3 weeks ago and noticed the jump off the line right away. Took me about an hour but if you're good with wrenches could go faster, there is lots of info on this site plus a youtube video that is very helpful also. Good Luck.
leafsrule17 is offline
