2006 F350 Chipped Ign Key - or not? - Diesel Forum - TheDieselStop.com
Old 07-07-2009, 12:48 PM   #1 (permalink)
Howdy,
I bought my truck used and it came with only one key and a remote start. As prone to loosing things as I am - I decided to get another key made. Off to the dealer I went - who then told me "Go to a key cutter on the mall - much cheaper than going through Ford, 2006 F350 keys aren't chipped". So I went to the Key Cutter who told me "I'll cut you a key - but it won't be as chipped one and your truck will only run a short time then the anti theft will kick in and it will die a horrible screaming death requiring a tow to a dealer and mucho dinero to breathe life back into it".. I little over dramatic I thouight - but what the heck - it is a mall and maybe he does a little busking in his free time. So I got him to cut me a key - figuring I could at least use it to open the doors - which it does - at least the driver's door - but not the passenger's - but then the other key doesn't open that door either - so no change there.
Anyway - what sayest you folks - Is the darn thing a chippy or not - how to tell?
Thanks !
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
rcgreg is offline
Old 07-07-2009, 12:50 PM   #2 (permalink)
Supporting Member
my03psd's Avatar
No chip.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 07-07-2009, 12:59 PM   #3 (permalink)
No Chip? - Great means less of a dip in the ole wallet
Thanks!!!!
rcgreg is offline
Old 07-07-2009, 01:00 PM   #4 (permalink)
Supporting Member
my03psd's Avatar
Excursions have chipped keys but not the trucks.
my03psd is offline
Old 07-07-2009, 07:43 PM   #5 (permalink)
sbuck's Avatar
The trucks have a fleet key with no chip
BOY DO I LOVE MY POWER STROKE Why didn't I buy a Cummins
10 EGR Valves
4 EGR Cleanings
1 EGR Cooler
2 Warped Heads
2 Blown Head Gaskets
2 Degas Bottles
1 Cracked turbo inlet pipe
2 Turbo cleaning
3 Exhaust back pressure sensors
1 PCM
1 EGR Valve wiring harness
new turbo
Entire Engine Wiring harness
2004 F350 Silver Crew Cab
Motor is bone stock
sbuck is offline
Old 07-07-2009, 07:47 PM   #6 (permalink)
jerzydiver's Avatar
I'll bite what is a fleet key
06 F350 XLT Crew Cab LWB FX4, power Captain Chairs / Snow Plow Packsage camper package / tow command / Amsoil oil bypass filter/ Billet Badges / A Pillar Quad gauges / overhead quad gauges / ExtremeAir compressor / Trian Air Horns / FX4 package / High Idle/Aux switch mod / Go Rino Push Bar / Go Rhino Rear hitch step / Hella Black Magic Driving Lights / Rhino Lining bed liner./ MRBP Cool Duals / KC 6x9 Long Range lights mounted to Third Brake Light / Pro Comp 305 x70 R18 Xtreme Mud Terrians</p>
jerzydiver is offline
Old 07-07-2009, 09:33 PM   #7 (permalink)
Mark Kovalsky's Avatar
The trucks DO have a chipped key - but only if you have the Harley edition. All the rest of the trucks (at least in 2006 and before) do not have chipped keys.
Mark
Mark Kovalsky is offline
