6.0L Power Stroke Engine and DrivetrainDiscussion of the 6.0L Power Stroke diesel engine and drivetrain in the 2003-Up Super-Duties and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Here's the deal , 71,500 trouble free miles until today .Been having some rough cold starts, so I took the truck out for some hard excelleration over the weekend to clean her out good . really made a difference too . the last thee days much smoother idle on cold mornings , smoother running all around.
I was cuising home today when the engine light came on and I lost 50% of power and engine sounded much quiter than normal . Got within 100 yds of home and she stalled . Couldn't get started again so I called tow truck. While waiting I scanned the computer and p2290 came up . Isx this code for ICP,injection control pressure ? Any clues what happenned ? Thanks for any help you can give me as I have been lucky and have had no problems with this truck until now .
BRL
06 F-350 CC SB Lariat 4x4 black w chrome package
3.5"d-pipe,centeury cap
275/70-18.00" toyo open country AT
With a P2290, the fault sets when actual pressure is less than the commanded by a specified value. Greater than 1 MPa (4-5 ICP commanded), greater than 3 MPa error (6-27 MPa ICP commanded).
Just in case you were wondering, MPa is a metric (SI) unit for pressure, or force per unit area. Pa is the Pascal, which is one Newton of force applied to one square meter of area (1 N/m2). MPa is a mega-Pascal, or one million Pascals. Since atmospheric pressure is 101 000 pA, or 101 kPa(approximately 14.7 psi), this is approximately 9 atmospheres (around 150 psi).
So, I'm guessing your ICP is bad?
Hope that helps you some.
__________________ SFC Fred Lynes
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch Package
Herrin Hauler Package
5R110 Torqshift
4.10:1 Dana 80 Trac-Lok
9,200lbs GVW
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles Wishin' I still had my '05 2500HD CTD Ram
Just got the call from the dealr and they say the hpop needs replaced . Is that the pump you were talking about fordboy ? I asked them if while they had it torn down if they would clean anything that was carboned up like the egr and ait2 sensors and they said they would . they also recommend cooling system fluid service .They don't drain & flush , they use a machine to pull out old and put in new . $79.00 and they don't change out therostat .What do you think ? Is there anything else I should have them check while its torn apart ? thanks guys , I trust your opinions !
Reason: typo
yeah thats the pump, wouldnt worry about the thermostat theres rarley problems with them but a coolant flush wont do anything but help, coolant in these things gets pretty nasty. if they clean the turbo im sure they will inspect it good and replace it if anything is bad but besides that not much else to do.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
Thanks for your help Fordboy . I was at the dealer today and I talked to the tech .He told me the egr looked like it had some serious issues as well as the ait2 sensor . I asked him how the turbo looked and he said it looked a little cruddy , but I got the feeling he wasn't very worried about it.Hope I can get them to clean and inspect it before they put it back together .I'll take your advice on the antifreeze also . Thanks for your help , I really apreciate you taking the time !
BRL
