2007 F350 stopped running - Diesel Forum - TheDieselStop.com
Old 01-21-2013, 09:05 PM   #1 (permalink)
Question 2007 F350 stopped running
My 2007 stopped running, had it towed to the shop. They called and said it was the glow plug control module. This doesn't make sense; the truck was running fine, at normal operating temp and just stopped. Had a friend say it could be the cam pos sensor?
RAMS1962 is offline   Reply With Quote
Old 01-21-2013, 09:46 PM   #2 (permalink)
Xx_Razgriz_xX's Avatar
Possible. Could be a High Pressure Oil System leak or a HPOP failure as well. You need a tool to check for codes and to check things like ICP and stuff. Some sort of tool is a must have accessory for these trucks.
http://www.youtube.com/watch?v=fifAzKKHq1k
SOLD
2003 Ford Excursion
6.0L PSD with 224,XXX+ Miles
Scangauge II w/ BlendMount Kit
Sinister Coolant Filter
+40hp FICM tune / No turbo-lag
MBRP 4" Turbo-Back straight piped
New HPOP 205k, FICM referb @215k, everything else original & stock
Old Faithful.
Xx_Razgriz_xX is offline   Reply With Quote
Old 01-21-2013, 11:00 PM   #3 (permalink)
Cam sensors do not fail very often on the 6.0 (but they certainly have had a few failures).
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD Billet WaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is online now   Reply With Quote
Old 01-23-2013, 04:03 PM   #4 (permalink)
Shop gave me a fault code of P0679, I can't find this code anywhere for the 2007 F350 6.0
Old 01-23-2013, 07:02 PM   #5 (permalink)
That is a false code. Is it an Independent shop and what code reader are they using?
Mark
Old 01-23-2013, 09:38 PM   #6 (permalink)
m-chan68's Avatar
P0671 = Cylinder #1 Glow Plug Circuit Failure
P0672 = Cylinder #2 Glow Plug Circuit Failure
.... and so on.
Last time I checked, a 6.0L diesel only has EIGHT cylinders.
Now, would be the time to do some datalogging of the usual 6.0L data readings that are immediately relevant to whether or not it will run, in order to pinpoint your issue, since no DTCs (or at least relevant ones) have set.
Ford Diesel/Senior/Master Tech
....who works at a dealership that now employs SOME half decent looking female employees since they overhauled most of the administrative staff
....and STILL hates working on E-Series with 6.0LFord Diesel/Senior/Master Tech
m-chan68 is offline   Reply With Quote
Old 01-24-2013, 06:54 AM   #7 (permalink)
So who deleted my reply. I replyed about 9:30 right after Bismic and before Mchan
dannyboy950 is offline   Reply With Quote
