3.73 -vs- 4.10 rear end MPG difference on a 6.0? - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 08-21-2005, 08:16 PM Thread Starter
What will be the difference in MPG in a 3.73 rear end -vs- a 4.10 in a dually loaded and unloaded?
Also, if I'll be towing a 15K trailer will the 4.10 rear end help out that much as compared to a 3.73?
2007.5 Chevy 2500 HD (Dark Blue) - LMM Duramax & Allison - C/C S/B 4x4 Z71 - Sirius Sat Radio & iPod (thanks PIE Interface) - Oil Guard Bypass Filtration - 2 Micron Caterpillar Fuel Filtration - EGR Blocker Plate - PCV Reroute - MBRP 4" Turbo Back - EFI Live
Never argue with an idiot. They will bring you down to their level and beat you with experience.
Arkapigdiesel is offline
post #2 of 10 (permalink) Old 08-21-2005, 09:40 PM
Re: 3.73 -vs- 4.10 rear end MPG difference on a 6.0?
The 6.0 likes the 4.10 better for towing. I went from a '03 3.73 6.0 to an '05 4.10 6.0 and there is a world of differance when towing. I am running a 6 speed in both trucks.
As far as mileage it all depends on the right foot. I have seen as much as 17 mpg (hand Calculated) running empty but overall average of about 15 mpg (city and highway combined)is most common and towing 12,500 plus I see about 12 to 13 mpg just depends on the wind and if I get caught behind a gasser (motorhomes, V-10's, Hemis, etc [img]/ubbthreads/images/graemlins/blush.gif[/img] ) that thinks he has got the power to pull the long grades here in Alaska. [img]/ubbthreads/images/graemlins/grin.gif[/img]
My Wife's Truck is a 2000 Super Cab, 7.3, DRW, XLT, 4X4,PSD, 6spd, 3.73, Dark Toreador Red, 4in DP, no muffler, 5 inch Black Cloud Slant Cut Stacks, SWAMPED, Stage III's plus a Custom Burned 6 position chip.
'12 Lariat, CC, DRW, 4x4, loaded
Big Boy w/ Big Toys is offline
post #3 of 10 (permalink) Old 08-21-2005, 09:41 PM
My Photos: (6)
I have a crew cab dually with the 4.10 rear. I see 12-14 city, 17-18 hwy
and 15-16 combined. Now, with my 5th wheel (15000lbs) hwy varies by speed and land level. So, I see 11-12mpg flat land @65-70mph. At 75mph, it drops to 9-10mpg. In the hills I see 9-10mpg @65-70mph. I hope this helps. Anthony
2006 Dodge Ram 3500 Quadcab LB 4X4 Dually, Cummins 5.9L Diesel
2005 Grand Junction 5th Wheel Trailer, 36' Model 36QRK
<font color="blue"> Sold do to problems - </font><font color="red"> Replacement </font> 2005 F-350 Crewcab LB King Ranch 4X4 Dually
<font color="red"> Buyback - May it RIP </font> 2003 Black/Silver F-350 Crewcab LB Lariat 4x4 Dually
awstas is offline
post #4 of 10 (permalink) Old 08-22-2005, 12:39 AM
There is a member on another forum I belong to who is deeply involved with the testing of ford, dodge, and chevy trucks. In his opinion (which from reading everything he posts, I highly value), when you have two ford Superduties, one with 3.73 and the other 4.10, and all else being equal, the 4.10 will get better mileage. It has to do with the load on the engine and how there is more load with 3.73 gears than with 4.10. The fact that there's more load on the engine with 3.73's is worse on fuel mileage than the fact that there's higher RPMs with 4.10's. Overall, the 4.10s would have better fuel mileage than the 3.73s, all else being equal.
Ryan Arthur
2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator and tee, ATS ported housing, Banks Big Head, CCV Mod, DP-Tuner flip chip, BTS valve body |||
taillights/running boards/mirrors/rear, side lights wired as turn signals, upgraded headlight harness w/ Xtravisions,
no more dingers, newer cupholder, fumoto, C-Betrs, locking fuel cap, mud flaps, wannabe air horn, Line-X, behind-seat storage shelf, intercooler foil wrap removed, SS HPX
ryaneverk2 is offline
post #5 of 10 (permalink) Old 08-22-2005, 08:20 AM
Not sure when Ford started with the bigger tires\wheels, but don't forget that this will 'change' the gear ratio as well. My '05 is closer to 3.55's with the 18" wheels than my '00 with the 16" and the 3.73's. I am thinking about getting a price for switching to the 4.10's because of what Ryan is referring to.
MarkOomkes is offline
post #6 of 10 (permalink) Old 08-22-2005, 08:34 AM
its not the size of the wheels - its the size of the tires that matter.
2003 6.0 Ext cab FX4 loaded XLT
March 03 build with 57,000 trouble free miles (so far)
4" turbo back SS MBRP (ohhh that whistle!), RSX3.5 alarm
8" Superlift with Bilsteins
37" Nitto Mud Grapplers on 17x10 Mazzi Hulk rims
weraracer is offline
post #7 of 10 (permalink) Old 08-22-2005, 08:36 AM
I am aware of that and factored that in. Still came closer to being 3.55 than 3.73.
post #8 of 10 (permalink) Old 08-22-2005, 09:44 AM
Yea the 34" OEM's mounted on 20" don't help the 3:73 much. If I have to change gearing to get another few mpg then I'll probably install lockers too. The Sterling diff's are new to me but I'm learning!
Wekiwa
2005 F250 CC SB 4x4 6.0 auto
Banks Big Hoss & K&N air kit & Xcal2 tuned.
Reg Return system with slighty larger injectors
A little turbo tweaking
Modified V-pipe and up-pipe assemble
Ceramic coated most stuff
Bypass oil filter kit
Black on Black
Wekiwa is offline
post #9 of 10 (permalink) Old 08-22-2005, 10:28 AM
homepukes's Avatar
My Photos: (11)
But my wife keeps telling me size doesn't matter.
2008 King Ranch CC 4X4
homepukes is offline
post #10 of 10 (permalink) Old 08-22-2005, 01:20 PM
DSI
after putting my 315's on my truck, i switched out to 4:10's, which basically brought the truck back to stock again. i did notice a small increase in mileage, and a slight inclrease in freeway RPM's, which was fine with me.
also, my factory gear's were almost toasted, they had obviously been setup wrong from Ford.
'04/03 F250 6.0/Torqueshift XLT Crew Cab... 4in, 4.10's, 315's on weld's, Stud's, O-Ring's, Injector's, Fuel Mods, AFE Intake, and a MagnaFlow Exhaust...
DSI is offline
