350 PSD brakes - Diesel Forum - TheDieselStop.com
Old 05-19-2005, 01:07 PM   #1 (permalink)
350 PSD brakes
My 2004 350 dually PSD brakes are acting funny. When you press the brake pedal, the pedal is spongy, and the engine gets louder. I know that the diesel engine works different than the gas engine as far as brakes are concerned,what could make the engine vibrate when I press the brake pedal? [img]/ubbthreads/images/graemlins/confused.gif[/img]
Chino is offline
Old 05-19-2005, 04:50 PM   #2 (permalink)
CaptSkup's Avatar
Re: 350 PSD brakes
Only thing I can think of right now is the possibility that the same pump that provides the fluid under pressure for the power steering system and the brakes is not operating properly. I believe since the diesel engine lacks the necessary vacuum to operate conventional powered brakes that the power steering pump provides the power for the brake booster. Could be low on fluid, air in system or the drive belt does not have the proper tension. Just a wild guess.
Skilled technicians seem to be lacking from the site today, somebody has to work for a living.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
Sea Ray 240 Sundeck
http://community.webshots.com/user/C...host=community
CaptSkup is offline
Old 05-20-2005, 11:42 AM   #3 (permalink)
Re: 350 PSD brakes
Thanks for the info. I'll check the power steering canister to see if its low.
Chino is offline
