4 Wheel on The Fly Not Working - Diesel Forum - TheDieselStop.com
Old 11-01-2009, 09:44 PM   #1 (permalink)
We were just down in Arizona driving in deep sand and when I shifted into 4x4 on the dash nothing happened, even though the 4x4 dash light came on. And, I got stuck. When I got out and locked in the hubs the front wheels started driving so we know the transfer case is ok, just no hub lock. We had several days of this kind of driving and each time we locked the hubs we were ok. At the same time I was continuing to shift the dash lever to 4x4.
I don't know how the dash shift communicates with the front end, but would appreciate some ideas about what I am dealing with. I have shifted into low 4x4 and the truck does go into low gear ok, just no front end drive.
This is a 2003 6.0l 250 with about 100,000 miles.
John Sanborn
Delta, CO
jcsanborn is offline
Old 11-02-2009, 01:09 PM   #2 (permalink)
KevinTamu's Avatar
You might have ripped a vacuum line off, I'd look around for one that's loose.
2006 F-350 King Ranch 4X4 - 63K miles
- Jl 13w7 powered by 1000/1v2 --- 2 Yellow Tops
- Jl 8w7 powered by 250/1 --- 220 Amp HD Alternator
- JBL performance components powered by Jl Amp
- All ran by Double Din Pioneer --- ARP STUDS
- 30 Farad Stinger Capacitor -
- 4.5 Don. Rac. Lift Kit --- Eric's Custom Tunes
- 35X13.5 Dick Cepek --- 4 Guage Pillar Mount
- 18 inch Mazzi chrome rims
- Excalibur remote start alarm
- 5 inch custom exhaust
- Many more cosmetic mods and SCT custom tune.
KevinTamu is offline
Old 11-02-2009, 01:28 PM   #3 (permalink)
Supporting Member
my03psd's Avatar
Definetly vacuum problem, either torn line, bad vac. pump, or like my truck it was leaking at the hub bearings relaced bearings and been fine ever since.
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 11-08-2009, 12:13 AM   #4 (permalink)
3/4tonman's Avatar
Send a message via AIM to 3/4tonman
If it is the vacuum seals they are pretty pricey from Ford too. Found out the hard way that mine wasn't locking same as you. When I replaced the seals, bearings, and left outer half shaft I also upgraded the lock out with Warn locks. I had to replace the lock outs anyway. The OEM hubs were seized up around the oring and wouldn't twist. Thank you previous owner who did no maintenance!
  1. 1971 F250 Camper Special 390, c6 auto, 4x2, 63k original miles, rebuilt engine. It's had a hard life.
  2. 1984 F250 6.9 IDI, 4-speed manual, 4x4. Rolled so now its a project.
  3. 1985 F250 351W, C6 auto, 4x4. Dads truck.
  4. 1988 F250 7.3 IDI, C6 auto, 4x4. Bought it with new heads and rebuilt injection pump. Since then new parts include ball joints, brakes and brake components at all wheels including parking brake cables, fuel sending unit, injector return kit, belts, starter, batteries, and alternator. Sno-way 9'1'' v blade. Ready to make some money!
3/4tonman is offline
