4x4 not working - Diesel Forum - TheDieselStop.com
Old 11-05-2009, 07:18 PM   #1 (permalink)
4x4 not working
Just installed new vacuum pump and 4x4 still won't lock in. When I turn the switch on the dash it starts blowing out the defrost. Checked the switch on the firewall next to the pump and it started to blowing out the vent again but still not locking in when you put it in 4x4. Checked all fuses and they are good. 2005 F-250 6.0L Is there a motor on the trans. and would this cause this? Also switched hubs to manual and nothing happened.
2005 F250 Fx4
First Diesel And Loving It
bpathfinder is offline
Old 11-05-2009, 07:41 PM   #2 (permalink)
4x4-Defrost issue
You may want to see some of the other posts on this as I had a similar problem where my front hubs would not lock into 4x4 after switching into ESOF but I still could put it in 4x4 and manually set my hubs and they worked. I changed out to the WARM premium hubs and if I want to 4x4 I put them in lock and then switch the knob up front (I never needed ESOF anyway!). I just have to take the time to cap off my lines to stop the defrost issue.
gcoutlaw is offline
Old 11-06-2009, 04:34 AM   #3 (permalink)
I just had this problem. We had to replace the relay and the vacuum switch on the fire wall. I put in a new shift motor and cab switch too before we found it was the relay. After we replaced the motor & cab switch still no go, this is when the tech found the bad relay, we replaced it now it would shift but not lock out the hubs so the vacuum pump on the fire wall was replaced and it all works good now. I would check your fuse in the cab to see if it has power to it. Mine did not so thats where the relay showed up. The tech said it got wet.
durantdiesel is offline
Old 11-06-2009, 07:13 AM   #4 (permalink)
Edit - are your hubs not engaging or is it your transfer case that is not engaging?
If you have the defrost coming on when it shouldn't, you have a vacuum leak somewhere (behind the glove box, at a hub or two, or at the heater control valve)
Mark
bismic is online now
Old 11-08-2009, 04:55 PM   #5 (permalink)
4X4 Not Working
Friend of mine had the same problem with his 06 model. I replaced the relay on wall next to the pump Ford part #7C3Z-9H465-A on both of them and it fixed the problem. Dealership was the only place to get it. We paid $138.04 for two of them and I installed them. 8mm wrench and 10 minutes not bad
2005 F250 Fx4
Old 12-21-2009, 12:46 PM   #6 (permalink)
Kellyo77's Avatar
I know this is digging up an old thread and a beaten to death issue but I just wanted to throw in my 2 cents.
I'm having the same issue, and found that my vac solinoid was bad so I replaced it. My SOTF worked right after replacing it exactly one time. And I'm back to not working again. My vac pump works. It runs and then stops once vac is built up. If I unplug a vac line it starts running again. I figure that since it stops running, that it doesn't have a vac leak and I can't find one if it does. Guess I am down to hub seals. I will keep checking. Pain in the ass. I looked for some good manual hubs to replace all that crap but no luck. The end.
2006 F250 CC SB 6.0 4x4 Lariat
SCT XCal 2 tuner/Harco Performance
Zoodad
Kellyo77 is offline
Old 12-22-2009, 08:08 AM   #7 (permalink)
Replacement Hubs
Kelly077,
I just said screw it and took off the Ford ESOF hubs (which when I took out were just pure CRAPOLA in my opinion and put in a real nice set of WARN GOLD-PREMIUM hubs. Hubs and install were like 300.00 at my local 4x4 shop. If I need to go into 4wd, I just spin them into lock and use the selector switch inside and all is just fine! I do not live up north in the snow so ESOF was really useless. Hope that helps.
baja25sst is offline
Old 12-22-2009, 08:19 AM   #8 (permalink)
rock_doctor's Avatar
That is really the best way to do it. When i need 4wd i just manually lock the hubs and then click the dash switch for the transfer case. When i got my 08 i went with manual hubs and manual transfer case. As a side note, when you get air out the defrosters it means there is no vacuum. That generally means either the hubs are leaking vacuum or a hose is leaking/came off. The defroster is the default if there is a loss of vacuum in all automotive ac/heat systems. You can disconnect the hubs and plug the lines. if you have vacuum then hubs are leaking. If still no vacuum then there is a hose or pump problem.
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 12-22-2009, 12:07 PM   #9 (permalink)
Kellyo77's Avatar
I have looked around on the warn website and don't see a listing for the 2006 f250. It only shows up to 2004. Anyone have a part number?
Zoodad
Kellyo77 is offline
