4X4 Switch - Diesel Forum - TheDieselStop.com
Old 05-08-2005, 09:26 PM   #1 (permalink)
4X4 Switch
The other day I turned my switch for 4*4 and it did not kick in. The indicator light did not light up either. I tried again did not work again. Then I turned the ignition off and restarted the motor and everthing was back to normal. I have switched it in and out several times since then, no problem.
I am curious have any of you had this problem and should I worry about this. Any help will be appreciated.
Dave
2005 psd 4*4
DAVEHELLO is offline
Old 05-08-2005, 09:45 PM   #2 (permalink)
dbennett48's Avatar
Re: 4X4 Switch
I have never liked ESOF 4X4. I like the lever that you pull and you can see and feel it go in or out. I have never owned a "shift on the fly" transfercase.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 05-08-2005, 11:01 PM   #3 (permalink)
Re: 4X4 Switch
Try holding the brake pedal down firmly when switching.
-T
2008 F550 6.4 w/ pickup bed
kehale is offline
Old 05-08-2005, 11:54 PM   #4 (permalink)
hitecdan's Avatar
My Photos: (22)
Re: 4X4 Switch
You should be able to engage 4-wheel drive HIGH while the truck is in gear and moving. To get into 4-wheel LOW the truck has to be stopped and in natural or park before it will engage. Did you turn the knob to far?
My html Version of the 6.0L Bible Now with 2005 Updates
$5 AIC
Born on date: Jan 20, 2003
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 4/15/2010)
The United States Constitution © 1791, All Right Reserved.
hitecdan is offline
Old 05-09-2005, 08:42 AM   #5 (permalink)
Re: 4X4 Switch
Moving it goes in good, stopped, it gets finicky for high range, but going to low you have to back up or move forward a little, stop and try it. Gear binding causes it to stick sometimes and rocking the truck back and forth lets it slip in. I "excersise" mine every week and it gets better with time.
2005 F-350 DRW 4x4 CC
2005 F-350 DRW flat bed
tucmoto33 is offline
Old 05-09-2005, 08:52 AM   #6 (permalink)
Re: 4X4 Switch
Dave,
Mine went bad last year with only 400 miles on it. Sounds like the same type of problems i was having. Every once in a while it would not go in and once i restarted it, it was fine. Got to the point that 4 high would engage but 4 LOW would not. Took it to the shop and they replaced what i was told was the 4 Wheel Drive MODULE?
I did not recieve my paper work bc i picked it up after hours and well sorta forgot about it. Since then no problems at all. I use mine about 1 or 2 a week..and 32k and doing just fine!
PM me if you need some more info...
Byrdman-
REPLACED...2003 Ford F-250 6.0L, AUTO, Crew Cab, Lariat, 4x4, Quad Captin Seats Leather, Sunroof
UPGRADES:Full Turbo Back Exhuast, Cat delete pipe, Pro-Comp 4' Lift W/ BFG AT's
FOR MY NEW 06 CC King Ranch, 6 OH, Quad Captains, 4x4, 20'' Rims, WHITE and Beige!!!
joeystrit is offline
Old 05-09-2005, 12:00 PM   #7 (permalink)
Re: 4X4 Switch
I have been using these switches on my chevy's and gmc's. They too go bad now and then. When it did not work for me now-- no lights came on at all. On my other trucks the lights came on but nothing happened. Seems like a computer glich. We will see. I use my 4*4 on a regular basis in my line of work. So I should find out if it is going to go bad pretty quick. I only have 7000 on the truck so I am in good shape. This is the very first problem I have had with this truck. So far I couldn't be happier with this truck it kicks butt.
Thanks for all the info
Dave
[img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
