5" vs. 4" inch exhaust - Diesel Forum - TheDieselStop.com
Old 03-07-2009, 12:13 PM   #1 (permalink)
Howdy,
Does anyone know what the pros or cons are to having a 5 inch system over a 4 inch? Does the additional inch make that big of deal, or is it just a waste of money? My main reason for putting a larger exhaust system on is to lower my EGT's when towing our toy hauler, plus I like the sound
Thanx,
Roach
Roach45 is offline
Old 03-07-2009, 01:00 PM   #2 (permalink)
Spoolin'6.0's Avatar
Send a message via AIM to Spoolin'6.0
i have a 5inch mbrp cat delete and it sounds fing awesome most people say the bigger diameter and lower the egts and the 5 inch is way louder then the 4 inch but thats just me i would go with a 5 in ebay has them for $500-600 all day long thats where i got mine 550 to my door
Spoolin'6.0 is offline
Old 03-07-2009, 01:24 PM   #3 (permalink)
5" stack is the way to go
NavyF350 is offline
Old 03-07-2009, 05:16 PM   #4 (permalink)
JimmyDee's Avatar
My Photos: (24)
Most of the oldtimers on this site will agree that there is no advantage to going to a 5" exhaust. They may look good and sound great but there will not be a significant decrease in EGT with the 5".
Now if you are going to 400-500 HP, maybe but that is a different story.
Jim
2001, F250 4x4, CC, Auto; Mobil 1 in transfer case&Trans.; Frantz Bypass Filter; "Hutch" fuel mods; Sonnax/Tricum mod; 4" Exhaust, 30" MagnaFlow; Attitude in A-Pillar and tranny gauge in Dash; AIS; EASE Diagnostics; Reese Slider Hitch; Fr Rotors, Cryo Treated&Slotted by ART.
JimmyDee is offline
Old 04-02-2009, 02:28 AM   #5 (permalink)
Originally Posted by JimmyDee View Post
Most of the oldtimers on this site will agree that there is no advantage to going to a 5" exhaust. They may look good and sound great but there will not be a significant decrease in EGT with the 5".Now if you are going to 400-500 HP, maybe but that is a different story.
Jim
That is the main issue.....if you aren't running stacked chips...then you don't really want to do a 5 inch exhaust. The problem with doing a 5 with no cats AND NO PROGRAMMERS is that you will actually LOSE torque and hp.
2004 6.0Powerstroke ExtraCab. Indigo Blue over Tan, Super Chip, AT's
2007 6.0Powerstroke CrewCab. Silver, Chrome package, SuperChip, MBRP Cool Duels Turboback
Burper/Puker
2 Degas Bottles, 3 Degas caps, 1 EGR Cooler, 1 Oil Cooler, 2 O-rings.....still puking.....
Also, two speed sensors, and about 13 damn tail light bulbs.....
StrokinTiger is offline
Old 04-02-2009, 05:55 AM   #6 (permalink)
Chuckdogg6.0's Avatar
Send a message via AIM to Chuckdogg6.0
Try searching the forums for more information. I see this issue being covered a few times a month.
2011 F350 6.2 XLT Crew cab SRW 4x4 3:73 E-locker Sync 4.2lcd
- Banks Exhaust w/ custom extras
- 5600k Head Lamps
- 5600k Fog Lamps
- Blacked Out Cab lights
- Blacked Out Mirror lights
TRADED--10/03 build F250 6.0 XLT Ext Cab 4x4 Auto,
06 Yamaha Banshee
Anniversary Addition
Powder coated black T5 exhaust
Chuckdogg6.0 is offline
Old 04-02-2009, 01:28 PM   #7 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
The 5" exaust will change the power band by moving up a few rpms. The egt difference is negligable unless you are in the 500hp+. The main difference is how loud it will be. A lot of people are running 500+ with 4". Losing the cat and miffler on a stock exaust will be compareable to a 4" with a muffler. A 5" exaust with out a tuner shouldn't give a noticable loss of hp. That argument is like the loss or back pressure on a turbo diesel thing. With a free flowing exaust your turbo will spool faster. Also on that note you will have better performance with some egts. Hot air in the turbo makes it work better.... Of course I don't mean 1300+ degree air but hot air has more energy than cold air for pushing the turbo.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 04-02-2009, 05:27 PM   #8 (permalink)
fxdwgi's Avatar
It is completely obvious that these posters know nothing of how a turbo engine works.
The difference between 4" or 5" is nothing but looks and sound.
2001 F-350 Lariat 4x4 Crew *4" BDS suspension lift w/315-75's * Ford AIS * MKO 5" exhaust * All 4 corners cleared * Front Reese Receiver * Draw Tite Fold Over Gooseneck * Reese 15K Sliding 5er * Gauges Whited Out * IC Foil Delete * Dieselsite Coolant Filter kit * DiPricol Optix White Faced Turbo,Pyro,Trans Gauges w/Dash Mount Pod * DP Tuner F5 60T 80E 120R 140X * John Wood Valve Body * ITP SS X-Over Line * ITP Boost Annihilator * 6.0 Trans Cooler * TCI Truck Master Triple Disc Billet Converter (-200 RPM) * Reviva Transmission * ESOF Converted to Manual Warn Hubs * 203' Thermostat * Turbomaster Wastegate Actuator * Gutted EBPV * Centramatics * Walbro GLS392 * Ford AICM * ITP Pre-pump * One Very Understanding Wife*
I AM AN AMERICAN, SO I DRIVE AMERICAN.
fxdwgi is offline
Old 04-02-2009, 07:45 PM   #9 (permalink)
so since i know absolutely nothing about a turbo diesel then explain to me why the "only" difference is looks and sound? a larger diameter pipe will flow more cfm's? more cfm = more flow? less restriction less heat? based on that awnser i question you knowldge. i simply stated that by allowing more flow it pushes up the rpm band of the engine. this is peak tq and hp. the egt difference is negligable and only a issue if you are able to get enough fuel and air (there are not alot of 6.0 engines above 700hp probably a hand full and in that area it would likely help egts) a stock 3.5" exaust straight piped will significantly lower egts and that is comparible to a 4" with stock cat and muffler. if you are looking at making more noise straight pipe will do this. the last part of my post was refering to the idea that the 6.0 needs back pressure to opperate corectly and this is not true. with a larger or freer flowing exaust the turbo will spool fater.
where is it exactly that you can teach me something?
2006 f250 4x4
crewcab short bed
lariat 6.0psd
soon to have isspro
fire/air/trans/fuel
else
Old 04-02-2009, 09:40 PM   #10 (permalink)
lol lol lol!!!! Genius I tell ya......genius!
Burper/Puker
Old 04-02-2009, 09:45 PM   #11 (permalink)
That is EXACTLY why I made my post.........backpressure....
Genius.....
Burper/Puker
Old 04-02-2009, 09:58 PM   #12 (permalink)
fxdwgi's Avatar
Sure....I can explain it you....hold on.
1. The turbo provides the backpressure.
2. You could put a 10" exhaust pipe on the truck, you still have to reduce it to the turbo housing outlet.
Nope...nobody is a genius with 6.0.....well except 1 guy at Ford and he even hates them.
Genius.....
Which is made by the turbo..............Genius.
I await the responses.....
fxdwgi is offline
Old 04-02-2009, 10:23 PM   #13 (permalink)
wait......I think you somehow missed the heavy doses of sarcasm in my last two posts.........
did you not notice that I pointed out that I was referring to backpressure, and even noted where the above poster had said that backpressure was not an issue on the 6.0?
I know how turbo works.....and I also know that the free-er flowing the exhuast, the better. In fact....if you could tow around a trailer with a huge vacuum cleaner on it hooked to your exhaust.....you would get even better performance and spooling.....
However....I was a believer in the rumor(which someone also mentioned above), that something was different on the 6.0, and that you could indeed "need" back pressure, even on the downside of the turbo. I was actually told this by a Ford tech....and by the guy that sold me my MBRP's at Truck Toyz.
Am I a genius? LOL, not by any means.....but I do like to refer to myself as one in a sarcastic response that pokes fun of.....myself.....
Btw....where is that little sarcasm emoticon when you need it......
Burper/Puker
Old 04-03-2009, 12:07 AM   #14 (permalink)
There is no lesson to learn evidently? I never argued back pressure I simply stated the rumor or wives tale that keeps surfacing.... There is more of a difference then just looks and sound which is eactly what I pointed out. You have the basics. Now go study 6.0 little 7.3 grasshopper
2006 f250 4x4
crewcab short bed
lariat 6.0psd
soon to have isspro
fire/air/trans/fuel
else
Old 04-03-2009, 08:42 AM   #15 (permalink)
fxdwgi's Avatar
Well since I work on these trucks for a living (ASE L2, Ford Senior Master, TRP) please educate a little grasshopper some more.
Also, how did you point out any change besides looks and sound?
fxdwgi is offline
