5R110W trouble - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 06-03-2012, 05:40 PM Thread Starter
ranger275c's Avatar
5R110W trouble
OK, I am sure this has been covered before but I am having trouble locating. I have this tranny in my 04 with almost 200k on it. it is have an intermittint issue with shifting between 3-4 and now it acts like reverse is loosing prime. I have changed the filter and fluid. Still no change. the matter seems to be getting worse. Sometimes it won't shift passed 3rd and reves up just fine. I can turn it off wait a min. and restart then everything is fine. I am thinking the VALVE BODY is going bad. But I have also read that there is a little rubber hose used in fluid pickup that could be bad causing the lose of prime. Are there any thoughts in this matter.
ranger275c is offline
post #2 of 7 (permalink) Old 06-03-2012, 07:13 PM
Mark Kovalsky's Avatar
My Photos: (6)
Since your transmission doesn't have a valve body I'm pretty sure that the valve body isn't the problem. I've never seen a little rubber hose inside the transmission. I have no idea what you mean by that.
Most likely it is a solenoid that is failing. It would probably be the direct solenoid since that one is used for fourth gear and reverse.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #3 of 7 (permalink) Old 06-04-2012, 02:05 PM Thread Starter
ranger275c's Avatar
ok, you got me. it is a solinoid body.
post #4 of 7 (permalink) Old 06-05-2012, 12:15 PM Thread Starter
ranger275c's Avatar
I know I can replace each of the soleniods, but not knowing exactly which 1 is the 4th gear/reverse I want to replace the whole thing. not only that its cheaper to. So what is the procedure to do this. Past the obvious. I know there are like 6-8 bolts holding the body in but after I remove them should it fall out or is there a wire harnes that needs to be disconnected and if so is this the same harnes on the outside of the tranny?
ty for your input.
post #5 of 7 (permalink) Old 06-05-2012, 02:00 PM
My Photos: (6)
Each solenoid has it's own electrical connector. It is pretty obvious once you get the pan off.
Mark
Former
post #6 of 7 (permalink) Old 06-07-2012, 12:01 PM Thread Starter
ranger275c's Avatar
ok, lets try this, does any1 have a diagram of the SOLENIOD BODY show the location of each with a discription and part number?
post #7 of 7 (permalink) Old 06-07-2012, 07:57 PM
dieselmac's Avatar
Try these.
File Type: pdf Tech Info, Solenoid Function & Operation.pdf (396.7 KB, 761 views)
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
