6.0 at 49 below (below zero that is) How much radiator can I cover? - Diesel Forum - TheDieselStop.com
Old 01-21-2013, 11:07 AM   #1 (permalink)
Junkers88's Avatar
Just got back from our wedding in Key West Florida and landed in -49 degree temps with the wind chill. The truck sat overnight at Ford after some repair work was done and even plugged in it was a slow start. No smoke and no miss though so I'm happy.
This morning it was -53 with the wind chill and I went outside to check the fluids etc and noticed a small puddle about the size of a .50$ piece under the truck. After some looking it seems that the block heater kept the truck warm enough that the system pressurized and a small leak developed at one of my coolant filter connections, no worries it was an easy fix.
That all brings me to my question. How much of the gill surface can I cover and not jack something up. I've got the feeling I've asked this before but can't remember it it was here or on my Toyota forums with the 4runner. Last night on the way home the ECT would hit 194, the t-stat would open, I'd get hot air out of the vents, then the cold coolant in the radiator would hit the t-stat, t-stat closes, ECT drops to 178 and I get no more heat. Very cold 1.5hr drive home.
This morning I cut a thick piece of card board and covered everything except the two vertical openings in the grill. Will that still provide enough air flow to keep from frying anything? I usually start the truck from inside and let it warm up for about .5hr before going outside and I can't see it from the apartment. If I can leave it then I'll paint it black tomorrow so it doesn't look quite so hideous.
Thanks folks!
05 F350, 6.0, K&N intake, Magna Flow 4", Edge Insight CTS, Sinister bypass coolant/oil filter system, Sinister EGR delete, more to come!
Junkers88 is offline   Reply With Quote
Old 01-21-2013, 11:24 AM   #2 (permalink)
Thats hard to answer I am not used to that kind of temps. Lol we seldom see below freezeing. On our class 8's that do stationay work I have covered no more than 3/4 of the radiator service area. Not shure what to recomend for you. Geeze 53 below is hard to comprehend, I just put on a jacket just thinking about it. LOL
You need to leave some air flow I just have no idea how much to keep from going critical.
Wow I just walked out in the shop and grabbed a jug of Zerex's version of ELC coolant 50/50 and it isn't even rated below -35 on its chart.
dannyboy950 is offline   Reply With Quote
Old 01-21-2013, 11:41 AM   #3 (permalink)
Junkers88's Avatar
Port Arthur Texas huh? Yeah I was born and raised in Seguin and spent many an hour down at the beach near you in my youth, wish I was there now.
You saying that the ELC 50/50 isn't rated below -35 has got me to wondering what the lower limit is on the Rotella ELC 50/50 that I have in there. Time for some research! Thanks for the heads up dannyboy!
Old 01-21-2013, 11:51 AM   #4 (permalink)
Wind chills don't count for equipment. Only living things. The wind will cool the piece of equipment faster, but it won't take it below the ambient temp. What did the thermometer say?
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator replacement, 2 batteries; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors and replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty.
Ford06 is offline   Reply With Quote
Old 01-21-2013, 11:56 AM   #5 (permalink)
Junkers88's Avatar
Ambient temp was 24 below yesterday and hovering around the same today.
Old 01-21-2013, 12:24 PM   #6 (permalink)
I cover off the rad completely and see what the temps got to, If it's too hot, open it up a bit.
Brian
MC5C is offline   Reply With Quote
Old 01-21-2013, 01:33 PM   #7 (permalink)
The intercooler alone will cool the engine with the rad blocked. -53F dang! hope some top notch lubricant is inside that engine! better keep it plugged in for sure!
Javier
1988 F250 dually All New 7.3 IDI, Banks Sidewinder.
C-6 with GearVendors overdrive 3.55 ring gear
Synthetic SAE 10W-30/SAE 30 Heavy-Duty Motor Oil,
Evans NPG coolant.
AMSOIL ATF in the transmission, AMSOIL gear oil in the diff.
20MPG city 25/28 hwy
IDIABUSE is offline   Reply With Quote
Old 01-21-2013, 03:28 PM   #8 (permalink)
BigDogOil's Avatar
You can cover the whole rad up, it won't hurt anything as long as you watch the ECT's. I cover mine right in once it gets to -35*C and have never had a issue yet. I remove the plastic piece that is under the hood and slip the cardboard in that way, it doesn't look as bad that way.
Also if I'm at lower speed's I use my tow/haul to keep the engine warmer when I'm driving.
2004 F 350 XLT 4X4 Crew Cab SRW
ScanGauge II
Glowshift Pillar Gauges
Blue Spring Upgrade Fuel Regulator
6.4 Bango Bolts
EGR Delete
Coolant Filter (Mine)
ELC Coolant
High Idle Mod
Zoodad Mod
BigDogOil is offline   Reply With Quote
Old 01-22-2013, 08:19 AM   #9 (permalink)
Yep, that is COLD!!! Yikes! Ready to go back to Key West yet?? What oil are you running?? I can't help you with the radiator cover question.
Old 01-22-2013, 09:49 AM   #10 (permalink)
drcampbell's Avatar
My Photos: (6)
Originally Posted by BigDogOil View Post
You can cover the whole ... as long as you watch the ECT's. ...
In case you're wondering exactly what temperatures to be watching for ...
The same high-ish temperatures that are OK in the summertime are OK year 'round.
If you're not towing, the heater core alone will probably dissipate enough heat to keep coolant temperature down where it needs to be.
Diesel engines pump a lot of excess air through their cylinders when idling or lightly loaded. A great deal of heat is dissipated that way.
Short answer: You can be quite aggressive about buttoning up for the winter.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
drcampbell is offline   Reply With Quote
Old 01-22-2013, 01:23 PM   #11 (permalink)
Junkers88's Avatar
Thanks folks!
Yes I'm ready to go back to Key West, put in four more resume's yesterday just hoping for something to happen.
I'm running 5W-40 Rotella synthetic as of last Saturday and am darn glad I got it changed when I did.
I'll keep the front end covered for the next few months and just keep an eye on the temps. This morning it did warm up a little quicker but since we're still well below zero I didn't expect any huge amount of change.
Old 01-22-2013, 07:20 PM   #12 (permalink)
indiana lineman's Avatar
I didn't see a high idle mod in your sig. Might be something to think about too. Lot's of info if you google it and easy enough to do. We were down to -2 this morning. Kind of a heat wave compared to you.
2005 SBCC
6.0 liter
3.5" straight pipe
indiana lineman is offline   Reply With Quote
Old 01-22-2013, 08:06 PM   #13 (permalink)
Junkers88's Avatar
Did some reading on it and I don't think it'd work for me. This truck will idle up on it's own after for sitting 90 seconds if the ECT is below 190.
Old 01-23-2013, 11:44 AM   #14 (permalink)
I can't brag much on my 12 degree start up this morning now can I!!
Old 01-23-2013, 05:30 PM   #15 (permalink)
High idle mod, helps wet stacking, faster warm up, helps keep engine temps up for heater. It may not help on wet stacking in your extreme temps, but regular idle at those temps can't be good. 1200 rpm idle and covered radiator might keep your heater warm.
06 F250 XLT sc sb /w 200,000plus miles
tow pkg.
snow plow pkg.
upfitter /w
high idle mod
back up camera
rear back-up lights
Blue spring and banjo bolt mod
Edge insite cts
new interstate batteries / may have hurt FICM
only Ford filters
Flushed/ CAT coolant
low coolant temps
two new thermostats
new coolant senser/ still LOW COOLANT TEMPS
mobile one oil/ going back to rotella T-6
REV-X / helped stiction
ARCH OIL AR 9100 /stiction cured so far 27*
ARCH OIL AR 6200 / @ 2 mpg increase
2stroked out is offline   Reply With Quote
