6.0 died on the road, any ideas! - Diesel Forum - TheDieselStop.com
Old 10-14-2012, 11:28 AM   #1 (permalink)
2005-6.0, F350, 133,000 miles on engine. Was heading to Austin yesterday, truck was on cruise control running 70mph going up a long grade overpass, the tranny dropped into passing gear and as I neared the top of the overpass I tapped the brakes to disengage the cruise, at that instant the engine went dead.
I have ran a FICM check and all the voltages are good, fuel is making it up to the secondary housing, (new filters a couple of months ago), all electrical systems seem to be working fine, no check engine light.
I know its a bad idea,just wanted to see if it was getting some air intake. Did a very quick check with starting fluid, engine will try and fire, it just seems like its getting no fuel whats so ever, it will not fire when cranking. I can hear the fuel pump running with the key on.
Any ideas? it just seems odd that it died instantly when the cruise disengaged, thanks for any help.
paul6.0 is offline   Reply With Quote
Old 10-14-2012, 12:15 PM   #2 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
Need to run a test for codes. Common to lose high pressure oil to injectors on a stock motor. A P2290 or P2291 would confirm that. There are a number of upgrade parts from Ford that make the 6.0 much more reliable.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. Many other custom features.
fordsforever73 is offline   Reply With Quote
Old 10-14-2012, 12:18 PM   #3 (permalink)
Interesting. Did you check any fuses? And you say you can hear the fuel pump running with the key on. Shouldn't it go off after a short time?
2005 F-350 LARIAT 6.0 PSD SRW AUTO FX4 (removed) CC SB White, International emblems, Tow Command, Upfitters, Line-X with pop-up bull ring tie downs, ScanGauge, Pioneer Appradio, Banks Technicooler and intake w/Zoodad, Dieselsite coolant filter (w/RMI-25), braided 4x4 lines, Mag-Hytec trans pan & diff covers, Fumoto oil valve (Motorcraft 15W-40), Knurled HFCM drain plug, Britebox, EZ-Down tailgate, BedStep, MBRP 5" cat-back (6" tip), Putnam class V hitch with 1upUSA bike rack, TransferFlow 30 gal toolbox tank (holding a Powerstroke tool) + 46 gal midship tank = 76 gals total with Stanadyne Performance additive and FPPF cetane improver... the rest is all stock. 73+k miles, 1700+ hours.
ljr869 is offline   Reply With Quote
Old 10-14-2012, 12:34 PM   #4 (permalink)
I did a cursory check of fuses, will do one with more detail now, The fuel pump sounds as if it is pumping up to pressure then the noise goes down to a very slight humming noise. Any idea of which fuses to check? Is there an easy way to check the hpop. And last, where can I get a code checking device? Thank you.
Old 10-14-2012, 05:42 PM   #5 (permalink)
rented a canobd2 check engine light tool, no codes being shown, now I am at a loss as what to do.
Old 10-14-2012, 05:57 PM   #6 (permalink)
My Photos: (21)
My SCT tuner is what gave me the low HPO code that came from a blown STC fitting. I know most cheaper OBII readers will not pick up all the codes. I personally don't know much about code readers or which ones to buy so hopefully others will chime in with more information. Only thing I can suggest is, getting the truck to a dealer, so they can plug in and run their diagnostic equipment.
Old 10-14-2012, 06:11 PM   #7 (permalink)
I would suggest reading the IPR value. You need at least 500psi for the PCM to okay firing the injectors. You have the STC fitting prone to failure, so that's a concern, but pretty easy to fix if that's the culprit. You may also have an HPO leak from a blow d-ring on a standpipe or dummy plug, or an injector oil rail o-ring. You can air test the system (but you must command ICP closed or hot wire it momentarily to check properly). I'd suspect the STC first, and just replace that in the event that IRP is not where it should be. If that dosen't cure it the leak is somewhere that you won't be doing double work to get to it, and that fitting is a time bomb anyway. Also look at the IRP screen and check for damage, as bad IPRs are not uncommon. With that kind of mileage the HPO screen should really be replaced, which is a PITA is you aren't doing an oil cooler at the same time. A frequent cause of IPR screen damage is junk getting into the HPOP from a bad screen.
Another thing to check is the ICP. It's on the front of the right valvecover. Unplug it and see if the engine will fire. If it does the ICP is bad, just replace it and rock on.
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ ID custom tune, FASS 195 pump, Gillette Diesel EGR cooler delete, Sinister Diesel coolant filter, ELC coolant, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARPs w/OEM HGs, Elite coolant lines, ITP RR fuel system, Warren Diesel 175cc injectors, Powermax, BD CCV, FICM.com FICM w/ ID tune, Elite UP, BPD water pump - shooting for the 12s!
'02 WRX - Outback rear disc swap, EBC green pads, pillar vane front rotors, TXS UP/TBE/TMIC, Perrin LW crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel & clutch, K&N filter, STi Group N motor/trans mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune for Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
TKOPerformance is offline   Reply With Quote
Old 10-15-2012, 04:41 AM   #8 (permalink)
There is a pretty good no-start sticky thread ..........
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD Billet WaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline   Reply With Quote
Old 10-15-2012, 01:39 PM   #9 (permalink)
Another thought, when you disengage the cruise control it cuts fuel, which is why sometimes it can be an abrupt, rough disengagement. I'm not saying it explains anything, just something to have in your knowledge bank.
Old 10-15-2012, 07:57 PM   #10 (permalink)
I am betting that it does have something to do with the cruise control, the instant it was disengaged the engine went dead, I checked all of the fuses,none bad, so I had no option but to tow it to the dealer today, $150 to check it out, I hope its a cheap fix...lol(sarcastic laugh)
Old 11-12-2012, 10:08 PM   #11 (permalink)
Any answers???
Did u ever find out what was wrong with it bro?
netojr2003 is offline   Reply With Quote
Old 11-13-2012, 06:22 AM   #12 (permalink)
Got it fixed, Iwas forced to take it to a dealer, it was the valve (IPR?)right before the HPOP and two blown dummy plugs. Had it all replaced along with the screen on the valve. total cost was 1785.45 I want to thank everyone here for thier help, you guys know what your talking about.
Paul
Old 11-13-2012, 08:18 AM   #13 (permalink)
Paul
Where are those dummy plugs. I am experiencing the same problem with mine. Turned off the cruise control and the truck shut down. Already replaced the ipr now wondering about those dummy plugs. Thanks
Paul
Old 11-13-2012, 04:56 PM   #14 (permalink)
The dummy plugs are in the oil rails which feed HPO to the injectors. Under the valve covers.
Old 11-13-2012, 08:00 PM   #15 (permalink)
I had the exact same thing happen when a seal on the top of one of the injectors spit out. The HP pump was handling it at revs but when I topped a hill and the cruise cut back the throttle and engine speed fell it shut down and never made enough injection pressure until it was towed and fixed (it was still in warranty).
There a few places where HP oil system could pop a seal and there is the STC fitting if not already replaced.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is offline   Reply With Quote
