6.0 Engine build date - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 02-18-2006, 05:50 PM Thread Starter
FINE69's Avatar
I know I've seen it somewhere, but where do I find the build date on my engine? Thanks in advance.
2009 F350 CCLB Larry-at, 6.4, all the toys....
FINE69 is offline
post #2 of 18 (permalink) Old 02-18-2006, 06:06 PM
My Photos: (5)
Re: 6.0 Engine build date
It's on a label on top of the ficm which is just below the coolant degas bottle.
It's listed day/month/year.
IIRC the label is yellow and it is just after where it says EN100
DED
6.0L, F-250 XLT, Torqueshift, S/C, L/B, FX4, 3.73 LSA, T/C, ESOF, ASG, Upfitters, SEIC,
Truck Build Date: 02/05/05 Kentucky
Engine Build Date: 02/03/05 Indianapolis
Gone but not forgotten - '99 7.3L F-250 XLT S/C, L/B
DownEastDiesel is offline
post #3 of 18 (permalink) Old 02-18-2006, 06:11 PM Thread Starter
FINE69's Avatar
DED, thanks, I went out and looked. It says 061204. So I guess that means December 6th, 2004, right? Thanks for the quick answer!
FINE69 is offline
post #4 of 18 (permalink) Old 02-18-2006, 06:28 PM
My Photos: (5)
Yup. December 6.
DED
post #5 of 18 (permalink) Old 02-19-2006, 10:41 AM
Fine69, according to your build date you could have the front main seal leak,if the build was in Indianapolis. This was very common from Thanksgiving that year to Febuary of the next year. It included mine to many others. If you haven't noticed you might want to check. [img]/ubbthreads/images/graemlins/vulnerable.gif[/img]
Mark
13 6.7 DRW Lariat FX4 CC Blue Jean Metallic w/ Sterling Gray accent. WeatherTech floor mats, Duraflaps, Firestone Ride Rites, and Airlift wireless compressor.
2007 F-250 King Ranch,Dark Copper, CC, 4x4, FX4, PSD, Torqshift, tow command, SOLD
2008 Cedar Creek 34RLSA
mlabelle is offline
post #6 of 18 (permalink) Old 02-19-2006, 10:46 AM Thread Starter
FINE69's Avatar
Thanks Mark, thats why I was asking about the build date. So far, no leaks, hopefully it stays that way. (I probably just jinxed myself). [img]/ubbthreads/images/graemlins/phoney.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
FINE69 is offline
post #7 of 18 (permalink) Old 02-21-2006, 07:54 AM
andrewbalser's Avatar
Just for verification...... on your build date. Check the build date of the truck, on the door jam. Make sure your truck build date isn't before 12/04. If it is then your engine is June 12, 04. I don't know if the date format on the engine stickers vary from plant to plant, but mine is in the format of MM/DD/YY...(052803) My engine came from the huntsville facility. You can sometimes use the truck build date to eliminate confusion because the engine build date has to be before the truck build date.
2003 RED F-250 Lariat FX4
SuperCab, Short Box, 6.0L, Torqueshift
"1991" Sun-Lite Pop/Up Slide-In Camper
DIY-Coolant Filter
137,000 as of 1/26/2012
3/19/11, Converted to (red) Delo ELC, new bottle & cap, all temps reading good, orig EGR & OIL coolers, probably thanks to the coolant filter, and previously frequently flushed Motorcrap Gold.
Keep on truckin
andrewbalser is offline
post #8 of 18 (permalink) Old 02-21-2006, 02:01 PM
DownEastDiesel,
My door jamb tag says 02/04 for the "Truck Build Date?" How do you find the specific day ? Also, the tag on the FICM says 03 DEC 2003 and is peeling off (very hard to read). How do I determine WHERE the truck and engine were built/assembled ??
Thanks in advance,
Roger
2004 Black over Orange Harley Davidson Edition
F250 CC 4WD SB 6.0L, MBRP Aluminized Straight Pipe
Sportster Sirius Satellite Radio Receiver
FireStone Rear Airbags
BAK Industries rolltop cover, Line-X
Truck Build Date: FEB 2004
Engine Build Date: 3 DEC 2003
2005 Eddie Bauer Expedition (Wife's Vehicle)
1999 31'JayCo Trvl Trlr
RLN2ND is offline
post #9 of 18 (permalink) Old 02-21-2006, 05:07 PM Thread Starter
FINE69's Avatar
Ok, I'll take a look. I do know my motor says it was built at Indy, if that helps. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
FINE69 is offline
post #10 of 18 (permalink) Old 02-21-2006, 05:15 PM Thread Starter
FINE69's Avatar
OK I looked in door jamb, it says it was built 12/04. Doesn't give an exact date. So I guess my motor was also built in December. Sound right? Thanks everybody for the help.
FINE69 is offline
post #11 of 18 (permalink) Old 02-21-2006, 05:22 PM
My Photos: (5)
DownEastDiesel,
Thanks in advance,
Roger
Roger, You get the exact build date of the truck off an oasis report. On the jamb of the drivers door it'll get you close by showing month/year.
In my case the jamb sticker shows 02/05. On my FICM sticker it also specifies Indianapolis plant.
I have to agree with the earlier poster who's date code reads mm/dd/yy on the FICM sticker. Check your door jamb sticker and better yet check your oasis report. The 2 dates should be very close with the engine being built first.
About the dreaded oil leak, I too have noticed a small amount of oil on the b/h. Initially noticed with 3600 on the odometer, at almost 11K now and still no oil drop stains in the driveway. I'm not going to bother the dealer with it unless it gets way worse.
Trucks running too damn good [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
DED
post #12 of 18 (permalink) Old 02-21-2006, 05:31 PM Thread Starter
FINE69's Avatar
So, do ya think my motor was built 6 months before my truck? Or am I wrong?
FINE69 is offline
post #13 of 18 (permalink) Old 02-21-2006, 05:49 PM
My Photos: (5)
I'd say the engine was built December 06, 2004 and I'll go out on a limb and guess the truck build date will be Wednesday, December 8, 2004.
I don't believe an engine would sit around for 6 months waiting to be dropped into the line. That just wouldn't make any sense.
DED
On Edit: Just checked out your photos. Man, that's a nice looking truck you got there.
post #14 of 18 (permalink) Old 02-21-2006, 07:36 PM Thread Starter
FINE69's Avatar
Thanks a lot! I appreciate it! Also thanks for all your help, thats what makes this place great! [img]/ubbthreads/images/graemlins/grin.gif[/img]
FINE69 is offline
post #15 of 18 (permalink) Old 02-21-2006, 07:55 PM
Fine69,
Well said !
Thanks Everyone,
Roger
RLN2ND is offline
