6.0 engine knock please help - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 02-01-2011, 12:46 PM Thread Starter
So I had 400 miles left on my trip yesterday and noticed at 70 MPH the engine was a little louder than normal, every time I engaged the turbo engine sound was normal till about 6 psi when sound returned. At idle there is a knock in the engine when I rev the engine noise goes completely away, oil pressure is fine, engine temp is fine truck runs fine except the knocking. Any help would be greatly appreciated
03 F350 160,000 miles
03 F350
04 gearbox toyhauler
76 Wife
bilabronco is offline
post #2 of 11 (permalink) Old 02-01-2011, 02:41 PM
JMTC's Avatar
Tough one! Lifter? Rod bearing, sometimes they have a sweet spot where the noise goes away during acceleration.
Pull dipstick & check for metalics in the oil, you should see brass flecks if its a bearing going.
Whats the frequency of the knock?
05 2500 chev silverado LT 6.6 dzl crew cab loaded 100000km stock
05 ford 250 6.0 ps crew cab 228000KM
EGR welded, new oil cooler, head gaskets & bolts
Case 580 super k
case 580 super m+
84 international s/a dump dt466 rebuilt (by me)
JMTC is offline
post #3 of 11 (permalink) Old 02-01-2011, 03:09 PM Thread Starter
Its sounds like a bearing knock
03 F350
76 Wife
post #4 of 11 (permalink) Old 02-01-2011, 08:33 PM
Is it smoking excessively? May have injector causing a knock.
djshum is offline
post #5 of 11 (permalink) Old 02-02-2011, 08:24 AM Thread Starter
There is no smoke other than the knock its fine
03 F350
76 Wife
post #6 of 11 (permalink) Old 02-02-2011, 08:42 AM
JMTC's Avatar
Did ya find any evidence on the dipstick or oil filter?
Case 580 super k
case 580 super m+
JMTC is offline
post #7 of 11 (permalink) Old 02-02-2011, 08:47 AM Thread Starter
I look there was no evidence of anything abnormal its at the dealer right now
03 F350
76 Wife
post #8 of 11 (permalink) Old 02-03-2011, 08:26 AM Thread Starter
Well ford mech seems to think its the flex plate - He removed the rubber plug on the tranny bell housing and the noise got a lot louder
03 F350
76 Wife
post #9 of 11 (permalink) Old 02-03-2011, 01:36 PM
Hank89 is offline
post #10 of 11 (permalink) Old 02-03-2011, 06:36 PM
Sounds like theres a chicken in there.
06 F-250 x/c 4X4 sb 17" alloy wheels. Tri-fold tonneau cover, weathertech vent visor,Ford floormats and splash guards. HarleyD headlights, Duplicolor bedliner coated bumpers, 08 rear bumper and taillights, herculiner rocker panels, XM radio, bosch wipers, Recon smoked cab lights, Edge Insight w/EGT probe, winter front.
06/10 ARP studs, turbo back silverline, new head gaskets, new oil cooler, upgraded turbo drain, fuel pressure reg upgrade, coolant filter, high idle mod, harpoon mod, pre-pump spin on fuel filter,ELC coolant, 6.4 banjo bolts, CCV reroute.
Truck weight empty fueled up, 4440 Front, 3040 rear, 7480 gross. Hex VXCF4,
SCT w/customs tunes from Vivian at Quick Tricks and Matt @ gearhead
worldwide73 is offline
post #11 of 11 (permalink) Old 02-05-2011, 09:45 AM Thread Starter
The diesel gods have been good to me, its fixed my torque converter bolts loosened up anyways it sounds normal again thanks for every ones help
03 F350
76 Wife
