6.0 engine replace. Pull Cab? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 04-25-2007, 11:57 AM Thread Starter
Replacing the engine in a 03 4X4 with an automatic. Ford dealer took the engine out of the pickup orignally, they had the pulled off the heads so it came out fine. Putting a replacment engine in that is in full dress and it does not appear that it will go without pulling the cab. Is this true or can you pull some things on the engine and make it go? thanks.
70burbulgy is offline
post #2 of 6 (permalink) Old 04-25-2007, 12:03 PM
FamilyRide's Avatar
Re: 6.0 engine replace. Pull Cab?
I think it has to come off. Either way, every tech I've head discuss it has agreed, it saves a ton of time to pull the cab.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #3 of 6 (permalink) Old 04-25-2007, 12:12 PM
My Photos: (38)
It is possible to fit the motor in without pulling the cab, but there will be a little "undressing" required. Take the turbo off the motor, and pull the front of the truck apart - radiator support, radiator, intercooler, condensor, grill, and other whatnot until you have a gaping maw to shove the motor through.
String your chain pretty tight, also, so you can fit the end of the cherry picker under the cowl when you get the motor most of the way in.
What sig?
GregH is offline
post #4 of 6 (permalink) Old 04-25-2007, 07:35 PM
i merely pull the tranny & raise the frt. portion of cab just enough to remove it. i don't even remove the turbo. i also remove the eng. to do the tsb for the h/p branch tube & coupler.i even reseal any leaks i find when its out. its not that bad if you have a rack. pull the frt. & middle body bolts to raise the cab.
certified ford dealer 7.3L,6.0L & 6.4L diesel tech & foreman
dvtech is offline
post #5 of 6 (permalink) Old 04-25-2007, 09:01 PM
Banned
We use the Rotunda engine lift.... bolts to the front of the block with a tie-back to the rear lifting eye.... This thing works like a charm with no chance of damaging the cowl or the cowl insulation. The engine will still require some undressing.
My hoist is unsuitable for lifting the cab so I just don't do it. Our two other diesel techs can lift cabs but have decided not to. FGor the customer, the sight of his truck split into so many pieces is unnerving. For the techs, we find that there are too many opportunities for squeaks and rattles.
While we might take a little longer, we don't introduce new issues either....
GrampyJim is offline
post #6 of 6 (permalink) Old 04-26-2007, 06:43 PM
I would just pull the cab if you have the ability. If not remove the turbo.
Gringo is offline
