6.0 fuel problem? - Diesel Forum - TheDieselStop.com
Old 07-01-2009, 09:55 PM   #1 (permalink)
6.0 fuel problem?
My 6.0 has been running rough in the morning for the last 2 months or so until it warms up, then runs fine all day. Yesterday leaving work for the day, the truck was running rough but I wanted to get out of there. Got about 1/4 mile down the road and i lost all power and the truck died. Cranked fine, but batteries seemed low. Had them tested, they were bad, and replaced both. Tried to start, fired up but ran rough for about 20 seconds and died. Now when i try to start, just turns over chugs along as long as starter is going, dies as soon as i let go of key. Shot some starter fluid in air intake just to see, fires right up fir a few seconds, dies. Thanks in advance for your answers.
MrAck is offline
Old 07-01-2009, 10:13 PM   #2 (permalink)
When's the last time the fuel filters were changed? It could also be a bad FICM.
Ljutic SS is offline
Old 07-01-2009, 10:47 PM   #3 (permalink)
HAD THE SAME SYMTOMS LAST WEEK TURNED OUT THE FICM WAS BAD CHANGE AND REPROGRAM RUNS FINE NOW OH YEA I WOULD LEAVE THE EITHER ALONE YOU BEGGING FOR TROUBLE WITH THAT
2005 F350 XL REGULAR CAB 6.0 11 FOOT SERVICE BOX DRW STOCK 212,347 ON THE CLOCK
1997 34.5 FLEETWOOD AVION 5TH WHEEL
2003 F350 XLT CREW CAB 7.3 STOCK DRW 85,000 on the clock
JOHN 3:16
timbo2 is offline
Old 07-02-2009, 12:31 PM   #4 (permalink)
Trigger's Avatar
Sounds like an injector or two. I had similar symptoms. I replaced all 8 of my injectors to be on the safe side. It isn't terribly complicated. Took about 8 hours to do all 8. Driver's side is easy, about 3 hours. Passenger side was a bit of a pain because of clearances.
04 X Limited 4x4
Trigger is offline
