6.0 glow plug check - Diesel Forum - TheDieselStop.com
Old 10-10-2012, 08:52 AM   #1 (permalink)
6.0 glow plug check
i am getting 0.0 ohms checking each of my glow plugs at the connectors at gpcm. i have a 2006. i have seen where a high reading means bad glow plugs what does no resitance mean? help
broomfieldj is offline   Reply With Quote Quick reply to this message
Old 10-10-2012, 09:05 AM   #2 (permalink)
i am using a fluke meter so i am sure of the readings
Old 10-10-2012, 09:44 AM   #3 (permalink)
rock_doctor's Avatar
Don't worry about it. If you have a bad glow plug it will set a code and will tell you which cylinder is bad. If you do have one bad then I would change them all since you have the wheel liners out and the plugs are cheap enough, about $10 each. "0" resistance means it is an open circuit, so one of the probes is not making a good connection, probably your ground to the block.
Member # 23075 Reged: 07/18/02
2005 Excursion w/ 6.0L PSD - Edge Insight, RCD EGR delete, Turbo Drain/Turbo Feed/Blue Spring/Oil Cooler Updates, Dfuser Coolant Filter, 240amp alt, fumoto.
2008 FX4 F250 CCSB w/ 6.4L PSD - Edge Insight, H13 Bi-HIDs, custom coolant filter, "all deleted", fumoto.
rock_doctor is offline   Reply With Quote Quick reply to this message
Old 10-10-2012, 09:58 AM   #4 (permalink)
RatherBNtheWoods's Avatar
I'm not certain that glow plugs are monitored individually. I do think they are powered in parallel per bank, and I know 0 ohms is a short, not an open.
Each bank will draw 150-200 amps when cold, so there isn't much resistance there. Maybe you didn't get absolutely 0, just a small r4eading and thought it to be 0. Use the old r=e/i
Have you a clamp on ammeter to go with your fluke mm? If so, reading current will tell you.
ps: If it were actually 0 ohms, the glowplug module would fry and then you would get a code.
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline   Reply With Quote Quick reply to this message
Old 10-10-2012, 11:11 AM   #5 (permalink)
It will set a code for a specific plug. I had a #7 code at the beginning of the summer. Changed them all, not bad once you get the plastic wheel liners out.
Old 10-10-2012, 06:57 PM   #6 (permalink)
dieselmac's Avatar
And it's only ~10amps per GP.
Scott
2006 F-250 PSD, Lariat
Mods: All the usual stuff
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline   Reply With Quote Quick reply to this message
Old 10-10-2012, 07:44 PM   #7 (permalink)
jeffws's Avatar
Mine set a code for #2 - I replaced #2 and the code was still there. I checked the harness and it was good. Replaced the GPCM and that fixed it.
05 F 250 CC PSD FX4
Dieselsite Coolant Filter
Edge Insight CTS w/ Fuel Pressure, EGT and Turbo Timer
Blue Spring Upgrade
HFCM Water Separator Drain Plug Upgrade
High Idle Mod
Mag-Hytec 6 Quart Diff Cover
Bilstein Shocks & Dual Stabilizer
285 70 17 Toyo's
Airlift Air Bags
18k Pullrite Superglide
06 Gearbox 295FS
00 Harley FLHR
06 KTM 525 EXC
06 Rhino 660
jeffws is offline   Reply With Quote Quick reply to this message
If you do not want to register, fill this field only and the name will be used as user name for your post.
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
