6.0 How many miles does the stock air filter last. - Diesel Forum - TheDieselStop.com
Old 08-13-2006, 05:46 PM   #1 (permalink)
I have a 2003 6.0 with 43000 miles on it. How many mile will a stock air filter last. On my filter the filter minder has not moved at all yet and the manual says no miles for time to change the filter just to keep checking the filter minder. I ask this because I am not shure if the filter minder is working because it has not moved yet.
onefordpsdman is offline
Old 08-13-2006, 07:46 PM   #2 (permalink)
Re: 6.0 How many miles does the stock air filter last.
I have 45k on my 04 and it has never moved, I was told by a ford service tech that because of so much volume the filter is there has to be alot of dirt in it to make it move. But anyways I replaced mine at 38k, I don't drive much on dirt roads, mostly highway.
timeforadmax is offline
Old 08-13-2006, 07:59 PM   #3 (permalink)
I just could not take it anymore and just changed mine this weekend. 43,200 miles (2,700 gallons of fuel ..assuming 16 MPG .. thousands of cubic feet of air) on a 2005 6.0 PS; Damn plastic thing-a-ma-jig has never moved ... I "hear" that the minder goes from "OK" to "Change" in a very quick time frame; good one day, bad the next.
I think the Donaldson technology is very sound and will not require changing for "many miles" when complared to the BAU pleated type. BUT ... I also belevie the long life of a diesel is very dependant on adequate clean air and clean fuel, and starving them of either could prove to be a disaster. Diesels require tons of air, so I chose to throw my money away and change it without the minder telling me to.
Like when she's washed, it makes no sense, but she runs better !!
I as most folks, follow the recommended 15K "change the fuel filters" so based on that, I thought a 3 to 1 ratio for the air filter was all I was willing to risk.
RaleighF250 is offline
Old 08-13-2006, 08:18 PM   #4 (permalink)
Your stock filter will hold 1600 grams of dirt before it fills up. Many, many miles on non-dusty roads.
RoyC
2005 Limited, 6.0L PSD, 4X2, Mineral Gray, 3.73 LS. Excursion Build date 02-08-05 6.0L 2005MY Engine Build date 01-03-05 Huntsville, Ala.
2005 50th anniversary Thunderbird Red with all
options except hardtop.
Old Ride: 2003 Excursion 6.0 L March 2003 Build 73,000 with no significant issues.
RoyC is offline
Old 08-13-2006, 08:19 PM   #5 (permalink)
I think it all depends on your driving conditions. The more debris, dirt and dust it sucks in the quicker its going to clog and move the filter minder. I suspect that by the time the filter minder moves, you will already be losing performance. I drive a lot of dirty/dusty roads, so I pull mine a couple of times a year and check it. The last time I pulled it a couple months ago at 38K it looked pretty filthy and I wrapped a pile of dirt out of it on the bench. I decided to change it since I had a spare.
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
Old 08-13-2006, 08:30 PM   #6 (permalink)
Changed mine at 50,000 miles...absolutely wasted the $65 for a new Donaldson Power Core (white media) and may even be tempted to put the old one back in....I don't drive in dusty conditions and I suspect it had maybe 8 oz of dirt.
Ian
Traded in 2004 PSD F350 Lariat 4X4 CC long box towing 2005 Cougar 5th wheel. Pleased owner of 2011 F150 SCab Ecoboost 4X4 3.73 max tow.
ikidd49 is offline
Old 08-13-2006, 09:03 PM   #7 (permalink)
77K and holding, I've ran some 100K and they all seem to plug up after that.
The put the filter minder on for a reason. Changing a filter lets a small amount of dirt into the engine, so changing it too often is worse on your engine.
But hey it's your money
2000 F-350 Lariat SC PSD SRW 4X4, Six speed, Dark toreador red, Ball Bearing Turbo, Coolmist Stage 2, Banks Big Hoss 5 chip, Big Head Actuator and 3.5 down pipe with Dynomax exhaust, PacBrake Exhaust brake, AIS Air Filter, Jordan brake control, 20K Reese fifthwheel Hitch, Reese folding gooseneck hitch, Rhino lining born 5/00
1998 35' Challenger fifthwheel double slide with 3600 Onan MicroQuite Generator,Washer/Dryer.
Wife drives a Black 2003 Excursion 4x4 Limited, 6.0 PSD
diesel_doctor is offline
Old 08-13-2006, 09:07 PM   #8 (permalink)
Does anybody know the actual weight of a NEW Powercore OEM Blue media filter. Just curious, as the determining factor seems to be how much weight in debris it will hold.
DRJ48 is offline
Old 08-14-2006, 09:06 AM   #9 (permalink)
This may be a simple question, but when checking the filter minder I assume you just look at it with the truck idling? I used to have a Ford Focus commuter car and the minder never moved on that thing either.
Steve
2006 F250 Lariat CC FX4 6.0 PSD Torqshift, Line X, Viper 791XV, IssPro Pyro. Engine Build June 6, 2005. Truck Build June 16, 2005
skroesen is offline
Old 08-15-2006, 07:23 PM   #10 (permalink)
Oh good, I thought that only happened to my truck! Just wait until it gets detailed next week....
2003 F350 XLT SuperCab, 4x4, 6.0L PSD. http://photos.thedieselstop.com/memb...1468&protype=1
JimmyP is offline
Old 08-15-2006, 09:34 PM   #11 (permalink)
OT
OT's Avatar
Due to our hi desert conditions was curious..installed new (blue) @ 17500 mi..little dusty/tapping, small amount fell out. Screen between grill/intake caught those big ones. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] Put new one in to compare, no diff. in performance/mpg etc. Kept old for spare & want hesitate to reuse.
New 3# 14 1/2oz...old (orig) 3# 15oz. Was surprised on wt. FWIW..filter minder didnt move.
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
