6.0 ICP sensor - Diesel Forum - TheDieselStop.com
Old 08-29-2009, 09:43 AM   #1 (permalink)
6.0 ICP sensor
Do you have to remove the turbo to replace the ICP sensor? PLEASE HELP
deputybmccarver is offline
Old 08-29-2009, 11:30 AM   #2 (permalink)
speedrcr78's Avatar
Nope you can do it without taking it off. It is kind of aggravating but it can be done.
speedrcr78 is offline
Old 08-29-2009, 01:34 PM   #3 (permalink)
Just did my ICP sensor
Okay, heres the low down.....I just changed my ICP sensor, and thanks to dweeb on here I finally found it.
You can change it from the top of the motor, but it was much easier for me to get to from under. I started on the top, but ended up having to get to it from the bottom anyway.
If you Google ICP sensor form top, I think it will lead you to someones post on here...the guy that did the writeup did an awesome job with pictures and everything.
Duncan_n is offline
Old 08-29-2009, 01:39 PM   #4 (permalink)
oh yea.
if you do it from under....you will need a 27mm deep socket that has been shortened about a quarter inch. I had to take a side grinder and trim some off of a brand new socket....but it worked.
From under, just go up the drivers side of the motor and you will see a small heat shield with three bolts. 2x 10mm, and one 13mm. The ICP sensor is right underneith the Y-pipe.
If you have any questions, shoot me an email....like I said I just replaced mine 3 days ago, so this stuff is fresh in my head......good luck!
nicholaseduncan@hotmail.com
Duncan_n is offline
