6.0 L 2004 superduty AT IDLE SURGING - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 12-06-2006, 10:51 PM Thread Starter
HI, HAVING ISSUES WITH THE TRUCK SURGING OFF OF IDLE...WIERDEST THING WHEN AT A REDLIGHT AND THE TRUCK WANTS TO LUNGE...IT DOES'NT DO IT ALL THE TIME BUT IS BECOMING MORE OF AN ISSUE AS WE DRIVE..ABOVE IDLE AT CRUISE SPEEDS WE HAVEN'T REALLY DETECTED THIS ISSUE.....I BOUGHT SOME POWERSERVICE INJECTOR CLEANER AND FUEL ADDITIVE....WHATTA YOU GUY'S THINK?????
jrw2scw is offline
post #2 of 17 (permalink) Old 12-06-2006, 11:11 PM
Re: 6.0 L 2004 superduty AT IDLE SURGING
I would be looking for a wire chaffing issue off the FICM where the harness exits the FICM and runs across the valve cover. I seem to remember that there was a recall on certain 04s for this issue. My 04 did not fall into the date range for the recall, even though I found it chaffing, so I fixed the issue myself with plastic conduit. [img]/ubbthreads/images/graemlins/smile.gif[/img]
PS: Please don,t use all caps as its hard to read and considered shouting here. [img]/ubbthreads/images/graemlins/smile.gif[/img]
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
post #3 of 17 (permalink) Old 12-06-2006, 11:46 PM
My 03 has been doing that since new. I've almost rearended people in the drive thru. Mine has been to the dealer to many times to count and they finaly told me it was normal and had no fix for it. The mechanic said hold the brake pedal harder.Good luck with yours and let me know if you here of a fix?
2007 F-250 6.0L CC SWB Lariat FX4
2003 F-250 6.0L CC SWB XLT FX4 (Lemon)
jmcholden is offline
post #4 of 17 (permalink) Old 12-06-2006, 11:51 PM
FamilyRide's Avatar
You need to find a dealer that doesn't provide crack to the diesel tech!! [img]/ubbthreads/images/graemlins/laugh.gif[/img]
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #5 of 17 (permalink) Old 12-07-2006, 12:15 AM
I would not put up with that. I would either make them (Ford) replace the engine wiring harness and attempt to fix the problem or replace the truck. [img]/ubbthreads/images/graemlins/frown.gif[/img]
DRJ48 is offline
post #6 of 17 (permalink) Old 12-07-2006, 12:49 AM
F350Lariat's Avatar
I have the same problem.
The following fixes have failed to correct the problem:
1. ICP sensor replaced twice
2. EGR valve replaced once
3. EBP sensor replaced once
4. Wire harness (chafing) replaced
The ICP sensor seems to be the first thing that the shop and tech line always try to replace. The surging idle on my truck went away for several months, but it has returned although a little milder. I've had several instances where I almost rear ended someone at the light. Surged to 750 RPM and went dead silent back to 500 RPM, before returning to factory idle at 600 RPM.
Good luck. Update the post if you find a solution.
2004 Ford F350 Crew Cab (SOLD MARCH 2012)
4WD Lariat 6.0L PSD Torqshift SRW
Med Wedgewood Blue / Arizona Beige
Tuff Country 1.5" Leveling Kit ... Hardcover Tonneau
Pro-Flap Mud Guards ... Toyo M55 LT285/75R16 Range E
GOS Racing Headlight Harness with Silverstar bulbs
Factory Ordered and Delivered: Feb 7, 2004
F350Lariat is offline
post #7 of 17 (permalink) Old 12-07-2006, 02:24 AM
not to take away from your issue at hand but.... come awwn you almost rearend people... are you sitting ONE inch from there bumper? do you sit with your foot OFF the brake? i mean with a little pressure on the brake and a 4oo rpm "surge" she still dont move much...
sometimes i really wonder. you got guys almost getting killed due to the lag of the turbo, and other guys almost rearending vehicle due to the truck "surgeing"
sure mine has alot of lag when cold... i drive accordingly, and yep she surges too but not going to rearend anyone from it...
heck my brothers turbo subaru wrx surges too its normal in those cars...
i can see you not wanting it to surge, but be realistic you arent gonna crash due to it.
2003 f250 crew...afe intake, gauges, 4 inch turbo back, sct tuner by Tadd , suncoast tranny.. Elite diesel studs and fire ring, stage one fuel kit, stage 2 injectors, Spearco intercooler.. ....aka HOT PURSUIT HAULER...
2006 badlands built moon buggy rock crawler rear engine turbo charged eco-tech.... aka HOTPURSUIT...FOR SALE pm for details
all vehicles running MAXXIS TIRES
hotpursuit is offline
post #8 of 17 (permalink) Old 12-07-2006, 02:42 AM
My Photos: (9)
mine is doing the same thing, i thought it was my powerpup as my dealership hasnt been able to get it to do it but now im wondering. ive had mine all the way up to 1100 and down to 300. its been at my dealer since november 10 or so, i told them im not taking it back till its fixed. i went on vacation and i go home on friday so trust me i will be driving it all day long until it acts up and then i will leave it running with them and i will get an answer asap. ill keep you posted, as for the wire chafing i asked about it and they said they didnt find anything. i told them to replace the egr (they like me and dont mind listening [img]/ubbthreads/images/graemlins/wink.gif[/img] ). and i had hte ebp done a lil bit ago but i dont think its that. my problem doesnt always happen though, you? it seems like no matter what though if it idles long enough it will sooner or later. let me know whats going on with you, the more info the more i can tell them and maybe get this done sooner for all of us. good luck
Jeremy
My favorite toy: Core i7 920@3.8ghz in Azza Hurrican 2000, liquid cooled cpu, Asus P6x58D-Premium motherboard on a shelf replaced with MSI Big Bang X Power x58, EVGA GTX 295s quad sli on a shelf replaced with 3 EVGA GTX 580 Hydro Copper 2 FTW tri SLI, 128GB SATA III Crucial Real SSD, Western Digital 500GB 7200rpm HD for storage, 12GB of ram@1600Mhz, 1100w power supply
2005 F350 cc, sb, Lariat, EDE SCT X3, 205cc injectors, Powermax HO, 5 inch mbrp exhaust, suncoast torque converter, outlook monitor, two tone blue and silver funtional ram air hood, 35x12.50x18 BFG MT KM2, Rancho RS9000XL with My Ride, ARB front and rear lockers.
1941 Willys Americar Coupe
2007 Mazdaspeed 6
2009 Jeep Wrangler Sahara
2012 Ford Focus SEL Sterling Grey
jgoff78 is offline
post #9 of 17 (permalink) Old 12-07-2006, 02:52 AM
Why not ask dealer for a data recorder...
2005 F-350 6.0 PSD 4x4 XLT. Magnaflow 4" Turbo-back Exhaust. No other Mod's
ExR90 is offline
post #10 of 17 (permalink) Old 12-07-2006, 04:07 AM
My Photos: (9)
good call
2007 Mazdaspeed 6
jgoff78 is offline
post #11 of 17 (permalink) Old 12-07-2006, 12:16 PM
Replace the ICP pigtail.
Tec80 is offline
post #12 of 17 (permalink) Old 12-07-2006, 12:18 PM
What he said. My truck used to do the exact same thing. The dealer did replace a few parts, but the final EGR/ICP/reflash solved everything.
Never has done it since.
04 F350 CC FX4 MAC intake, Progard filter, DR levelling kit and 35 X Terrains.
89 F350 CC 4x4 Longbed Lariat. 7.3 with ATS Turbo and K&N. --SOLD--
More mods as the money allows.
MonkeyBoy is offline
post #13 of 17 (permalink) Old 12-07-2006, 02:08 PM
dwelch1's Avatar
My Photos: (5)
mine was the same as Tec80 and MB stated above, the same also fixed my truck.
2015 F-250 Crew Cab, Lariat, 4x4 Magnetic
13K miles so far. Retrax Pro Cover
Relaced My:
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter
dwelch1 is offline
post #14 of 17 (permalink) Old 12-07-2006, 03:52 PM
It actually sounds like your torque converter is locking up. I had this problem after having my tranny rebuilt, small piece of waste got in the switches. Good luck.
2004 F250 FX4 6.0L
chrislinsky is offline
post #15 of 17 (permalink) Old 12-07-2006, 05:20 PM
Off topic a bit ..... BUT my 03 will surge at a light once and awhile ..... and it Always happens at the end of an oil change interval........ weird. ONLY does it then , no other time ever !!!
24hrsparkey
2000 f350 7.3 ccab 4x4 auto , DpTuner, AIH Delete, 4" Magnaflow . Only 130,000 miles on it.
and
2001 Ram 2500 auto w/cummins
24hrsparkey is offline
