6.0 No Start when hot - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 04-15-2010, 07:26 PM Thread Starter
Hi All I have a 2007 F 350 Now that when It gets hot It will not start. It has a new HPOP Fresh oil. When the engine is cold it starts fine with no problem. I checked it with a scanner and it is not building high oil pressure when hot. I can let it cool for a couple hours and it will crank and run until i shut it down then no start. Any Ideas where to start looking Thanks Jimmy
jydracing is offline
post #2 of 18 (permalink) Old 04-15-2010, 09:11 PM
hpop stc fitting or high pressure oil rail o ring leaking would be a good place to start
ricatic is offline
post #3 of 18 (permalink) Old 04-16-2010, 01:30 AM
los
los's Avatar
los is offline
post #4 of 18 (permalink) Old 04-16-2010, 07:24 PM Thread Starter
Hi All Well I had a little time today and done a little checking. I know for sure that when the engine gets hot I am loosing High oil Pressure. The scanner showes it at 265 pounds. I pulled the sen out of the valve cover and installed a manual gauge and only had 260 pounds. I feel that is not an electrical problem. I will start doing the air checks tomarrow. What really gets me is that you can start it and run it all day as long as you do not shut it off. But ounce you shut it off it is not going to crank back until it cools down. Thanks All Jimmy
post #5 of 18 (permalink) Old 12-10-2011, 06:41 PM
fire9199's Avatar
I just bought a 2007 F350 also and I am experienceing the same problem. It runs great but if I shut it off it won't start. I just got it back from the dealer yesterday. They replaced the sct fitting off the hpop and the plugs underneath the valve covers. Not sure, Is there anything else to look at? weak injectors?
fire9199 is offline
post #6 of 18 (permalink) Old 12-10-2011, 08:22 PM
They just did the STC work and the dummyplugs and standpipes and it is still having warm start issues ,,,, is this correct, or are you wondering if they addressed all of the weak points?
Mark
bismic is offline
post #7 of 18 (permalink) Old 12-11-2011, 12:39 AM
fire9199's Avatar
Yes, the dealer made it sound like those were the ares that were causeing my prob, but I just got back from driving it around for awhile, pulled in the driveway, shut it off and then won't start again. So still having the same problem.
fire9199 is offline
post #8 of 18 (permalink) Old 12-11-2011, 07:05 AM
The injector o-rings at the oil rail connection are also somewhat common leak points - especially if the oil rails are not re-installed properly.
I would take it back and talk to them about getting it fixed - and they shouldn't charge you any labor cost since they were into the system and didn't fix it, IMO anyway.
At a minimum, they should do the diagnostics for free and tell you if you still have low pressures in the high pressure oil system (ICP values). Get the engine good and hot before you take it to them and have them do the diagnostics right then (when it doesn't start).
Mark
bismic is offline
post #9 of 18 (permalink) Old 12-12-2011, 10:45 PM
fire9199's Avatar
I talked with the dealer again today. He said they replaced an injector and it is running the way it should now. I'll pick it up tom and hopefully all is well.
fire9199 is offline
post #10 of 18 (permalink) Old 12-17-2011, 10:42 PM
toughford6.0's Avatar
having same type issue
I have a 2003 f350 single axel lariet fx4 and just yesterday It started not wanting to start when its warm it been sitting at the our shop it was running great and then a couple of times it wouldn't start after being driven a little the while driving it just died I mean no sputter or loss of power slowly it just went dead the next morning's mg it started fine several times so today I went and drove it home about seven miles ran fine but once I got it home it wouldn't start this is my first powerstroke so I'm learning as I go I love this truck though please help it is my only way around
toughford6.0 is offline
post #11 of 18 (permalink) Old 12-18-2011, 10:33 PM
because you have an 03, you dont have an stc fitting, which was a common leak in 05-07. unfotunately, your icp sensor is almost below the turbo where in 05, they moved it to the passenger side valve cover. first palce to start is to take a look at icp sensor. if it and the wire harness have oil on them, they need to be replaced. some people pull the sensor and check pressure with a manual gauge. if thats not the problem, its probably stand pipes or dummy plugs which are under the valve covers.
05 f250 6.0 xlt ext. cab long box Fx4, 130k auto, 3.73's, stainless along bottom, 105 gallon L-shaped fuel tank, 8'6" Boss poly v-plow, 2 cracked y pipes, replaced egr valve, replaced ficm, 2 new napa batteries, new ford 140amp alternator, blue spring upgrade, scanguage II, sinister cooant filtration system, drivers side ball joints at 130k, retired juice w/ attitude on the shelf
**to do list**
egr delete, programmer, egt and fp gauge, coolant flush with elc, 5" turbo back
99 f250 5.4 xlt reg cab long box 4x4 5pd manual, 125K, 4.10s, L-shaped fuel tank, shot one plug
11 f150 King ranch 4x4 3.53s, CC 5.0 6sp, 2 tone white/tan, everything but tailgate step
Joe_r_dog is offline
post #12 of 18 (permalink) Old 12-18-2011, 11:20 PM
The ICP was moved in 04 (some 04's are behind the turbo and some are on the passenger valve cover).
The 03's have different standpipes and do not have the dummy plugs. The standpipes are not as common of an issue on the 03. For that model year, a high pressure oil issue (if you have one) is more likely to be a leak at an injector o-ring (at the oil rail), an HPOP discharge o-ring, or the HPOP isteslf.
Mark
bismic is offline
post #13 of 18 (permalink) Old 12-19-2011, 12:32 PM
Exclamation
Thanks for all the info I've had an injector that has been working when cold but as the engine warms it quits firing off so I'm betting injector seal kits are probably a good start just reinforced to get as much info as I can before beginning tear down
post #14 of 18 (permalink) Old 12-20-2011, 08:20 PM
Unhappy new development
Ok so I hooked up to a snap on odb2 scanner and found that there we're several problems map sensor, crank sensor, can, sensor, egr out of range, cylinder 2 not contributing, so loooks lie a new wire harness may be in order any thoughts?
post #15 of 18 (permalink) Old 12-20-2011, 08:57 PM
cam sensor and crank sensor codes are most likely from not getting sync (ie it is likely that there are no issues w/ these sensors or the wiring).
What code numbers did you get?
Mark
bismic is offline
