6.0 Oil Capacity??? - Diesel Forum - TheDieselStop.com
post #1 of 27 (permalink) Old 07-29-2005, 09:12 AM Thread Starter
6.0 Oil Capacity???
I have an 05 6.0. The owners handbook says the engine oil cap. is 15 qts with a filter change. This puts the level high on the dipstick. I've read on other sites people are using only 14qts. Is 15qts a misprint in the handbook, or is this an accuracy issue with the dipstick?
2stepn is offline
post #2 of 27 (permalink) Old 07-29-2005, 09:14 AM
Re: 6.0 Oil Capacity???
If you follow the right procedure, open and drain your filter first, you should get 15 in it. I have mine since new.
On edit, didn't mean to sound sarcastic [img]/ubbthreads/images/graemlins/tongue.gif[/img]
BE
2003 Lariat 6.0 Arizona Beige/Med Parchment Crew Cab 4wd Auto 3.73 born on 5/9/03
bedwards is offline
post #3 of 27 (permalink) Old 07-29-2005, 10:43 AM
2stepn - You doing the oil change yourself or dealer?
I am struggling with the same issues of what is the correct amount.
2004 F-250 Extended Cab Lariat
6.0L Powerstroke
No Modifications
WIPSD is offline
post #4 of 27 (permalink) Old 07-29-2005, 10:45 AM
lincster's Avatar
My Photos: (29)
I open and drain my filter first and 14 qts puts me right at the top of the hash marks.
2012 F350 4X4 Dually, FX4, Crew Cab, Ultimate Lariat Package, Oxford White, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
lincster is offline
post #5 of 27 (permalink) Old 07-29-2005, 10:51 AM
Are you getting a clean reading with that long A#$ dipstick?
Thanks for the info.
6.0L Powerstroke
No Modifications
WIPSD is offline
post #6 of 27 (permalink) Old 07-29-2005, 11:17 AM
Ditto for me. 14 quarts fills me up.
CMOS
2004 Ranger SCAB
Shopping for 99-2002 7.3 CREW
CMOS is offline
post #7 of 27 (permalink) Old 07-29-2005, 11:27 AM
lincster's Avatar
My Photos: (29)
I check it after it sits all night, so all of the oil should be drained down. 14 qts looks good on the dipstick for me.
lincster is offline
post #8 of 27 (permalink) Old 07-29-2005, 11:34 AM
Fourteen quarts puts me right at the max mark.
Mark
13 6.7 DRW Lariat FX4 CC Blue Jean Metallic w/ Sterling Gray accent. WeatherTech floor mats, Duraflaps, Firestone Ride Rites, and Airlift wireless compressor.
2007 F-250 King Ranch,Dark Copper, CC, 4x4, FX4, PSD, Torqshift, tow command, SOLD
2008 Cedar Creek 34RLSA
mlabelle is offline
post #9 of 27 (permalink) Old 07-29-2005, 11:47 AM
CaptSkup's Avatar
I also put in 14qts. I hate that friggin' dipstick. It has to be about the hardest stick I have ever tried to read. How come Honda and Toyota can have simple flat blade sticks that are very easy to read and my $45k truck has a plastic bulb on the end of the stick? By the time you yank the whole length out, it has picked up every drop of oil clinging to the sides of the stick. About the only way I can get an accurate reading is first thing in the morning after the truck sat all night. Love the truck and the PSD, hate that damn dipstick.
14qts of fresh Rotella sure smooths out the idle.
2008 F-450 Lariat Dark Stone Metallic over Pueblo Gold 4x4(manual shift transfer case, manual hubs), High capacity tow 4:88s, Off Road, Camper packages, Sirius Sat, Upfitter switches, DVD entertainment, tailgate step, traction control, Audiophile 6-disc, PTC Supplemental heat and heated seats(warm buns), rear sensors, traction control, tailgate step. Built May 8, delivered May 24
Reese Signature Series 24k fiver hitch, I installed it myself, best hitch I have found yet
Line-X bedliner, heavy duty floor mats
2003 Sunline F281SR(weekend getaways)
Sea Ray 240 Sundeck
CaptSkup is offline
post #10 of 27 (permalink) Old 07-29-2005, 02:00 PM
I just went 14 and it looks good. We will see after it sits tonight?
So much for following the directions.....
6.0L Powerstroke
No Modifications
WIPSD is offline
post #11 of 27 (permalink) Old 07-29-2005, 02:28 PM
Engine holds 15 QTS, however, the high preasure oil pump res holds .82 QT of this amount and it does NOT drain back into the oil pan. 14 QTS should be about right.
RoyC
I looked this back up in the 6.0L Bible and I was in error on the amount it is actually .95 QT see page 21 of Bible.
My Bad!
RoyC is offline
post #12 of 27 (permalink) Old 07-29-2005, 02:55 PM
what he said + Mine new smoked a light blue smoke and all of the sudden when i changed to 14 qts. it stoped, o by the way i had to clean my egr at 7k miles a result i attribute to overfilling my oil and driving it way to easy...just my 2 cents..
j.schall
2005 f250 PSD 4x4,CC,LB Magnaflow 4" turbo back exhaust.
moovet is offline
post #13 of 27 (permalink) Old 07-29-2005, 03:02 PM
Well, I've done it.
It took me about 31.5 quarts until it started coming out the hole where you fill it.
So...the total capacity is 31.5 quarts.
It wouldn't turn over when I tried to start it, though [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2008 F550 6.4 w/ pickup bed
kehale is offline
post #14 of 27 (permalink) Old 07-29-2005, 03:16 PM
Those Middle East countries love.......you...
j.schall
moovet is offline
post #15 of 27 (permalink) Old 07-29-2005, 03:17 PM
Why doesnt the dumb sh^&'s @ Ford tell the dealers this? It the oil pump res holds .82 which makes sense to me why dont they at the dealership put 14 in? I would like to know if the folks at Ford tech services know this and why it is not public. I have replaced a couple EGR valves myself. Is there any adverse effect to the engine with 15 in it. I would think that the engine tolerances are able to allow for this.
6.0L Powerstroke
No Modifications
WIPSD is offline
