6.0 oil filter - Diesel Forum - TheDieselStop.com
Old 03-29-2007, 12:46 AM   #1 (permalink)
6.0 oil filter
I have tried the serch function and it leaves something to be desired.
Where is the best place to buy your 6.0 oil filters at? Where can I spend the least and get the most for my money?
thanks
anmetcalf is offline
Old 03-29-2007, 12:50 AM   #2 (permalink)
Re: 6.0 oil filter
most people say wal-mart is the cheapest source but if there's something better I'm sure someone will speak up
2003 F-250 FX4, Super Cab, Long bed Grey. 6.0 Automatic, Spray on Liner
davidg5252 is offline
Old 03-29-2007, 10:23 AM   #3 (permalink)
Re: 6.0 oil filter
At your local International Truck Parts Dealer... Part numbers are as follows...
Oil Filter Kit - #1840752C91
Fuel Filter Kit - #1847170C92 (or #1847170C93)
Drain Plug - #2589259C91
2004 F-350 Lariat SRW <><
315 BFGs, Edge Platinum, ARP Studs, & B&W Goose
1998 Cherokee RockCrawler
NCfarmboy is offline
Old 03-29-2007, 10:45 AM   #4 (permalink)
Re: 6.0 oil filter
I get mine from the dealership that I work for but I agree that the best and cheapest place is International unless you don't have one in the area. I know that O'Riellys is very high. I would try to stay away from there if you can.
Matt Cearnal
2007 F-350 Lariat, Longbed, Crewcab, Stock right now but the fun is just begininng.
mattcearnal is offline
Old 03-29-2007, 10:53 AM   #5 (permalink)
FamilyRide's Avatar
Re: 6.0 oil filter
Bought my last ones from www.fleetfilter.com About $14 I think.
Prior to that I was in a bind and actually found a Walmart that had a couple and they were about $20.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 03-29-2007, 11:30 AM   #6 (permalink)
lesmmiller's Avatar
Re: 6.0 oil filter
auto zone is 19.00 and walmart about the same for the motorcraft,but i also bought a autoline which was the old ford part name,same filter,wrapped in plastic with the o ring same part # for 14.00
lesmmiller is offline
Old 03-30-2007, 09:29 AM   #7 (permalink)
Re: 6.0 oil filter
what do the charge at the international dealer??
2006 f-250 q-cab, lariat, 4wd medium wedgewood blue and arizona baige, bfg 305's
55k miles
1982 jeep scrambler
2001 bmw 525i 90k miles
ncmallard78 is offline
Old 03-30-2007, 11:37 AM   #8 (permalink)
Re: 6.0 oil filter
I use amsoils new filter - $31, lasts up to 25,000. You can always change it sooner for maximum protection.
http://www.amsoil.com/storefront/detail.aspx?ID=6932
Or the WIX 57314 is a good standard filter.
'08 F350 6.4 Lariat CC SWB SRW 4x4 3.73
JMFINLEY is offline
Old 04-03-2007, 07:58 PM   #9 (permalink)
Re: 6.0 oil filter
I just got the following price quotes from my local international dealer:
Oil Filter Kit - #1840752C91 $21.08
Fuel Filter Kit - #1847170C93 $37.00
Drain Plug - #2589259C91 $13.53
Bayshore International
6100 Redwood Drive
Rhonert Park 94928
707-584-1610
dgarzoli is offline
Old 04-03-2007, 09:30 PM   #10 (permalink)
fastzr1's Avatar
Re: 6.0 oil filter
I pay $14 at the local Wal-mart for a Fram. It has worked well for me.
Semper Fi
Ed
04' F250 C/C, SWB, 6.0L, 4x4, True Blue/Silver
ISSPRO Gauges, Firestone Air Bags, LEER Cap, Super Liner Spray In
I love my truck.
fastzr1 is offline
Old 04-03-2007, 09:46 PM   #11 (permalink)
Re: 6.0 oil filter
$19 at wal-mart for motocraft.
99 F250 XLT ext. cab 7.3 hypertech programmer. Wife asked me to trade it in for a crew cab.
01 F250 Lariat crew cab 7.3. Every option and superchips programmer. Best truck I ever owned. Traded in thinking the 6.0 would be better. Biggest mistake of my life.
03 F250 Lariat crew cab 6.0. Don't even want to talk about it. Spent more time in the shop than in the driveway.
06 F250 Lariat crew cab. MBRP full exhaust . I actually like this truck. Probably the closes I will ever get to a truck like my 01.
gmalott is offline
Old 04-03-2007, 10:07 PM   #12 (permalink)
FTG-05's Avatar
My Photos: (25)
Re: 6.0 oil filter
Keep in mind that there are two kinds of oil filters that will fit the 6.0: OEM-type and non-OEM type.
A pic is worth a thousand words.
Filter on the right is the OEM motorcraft filter. The one on the left is the Wix, part number given in a post above. It's hard to see it here but the Wix is slightly shorter and is not a "flat-top" as is the OEM type.
http://photos.thedieselstop.com/show...mp;thecat=3624
Here's another pic, this time they're switched: OEM on the left, Wix on the right. You can clearly see, even if blurred, the flat-top of the OEM filter. You can also see that the OEM is taller than the Wix.
The OEM types won't let the oil drain back when you shut the engine off. They will also work, if it matters to you, with the Oilguard oil bypass filter caps. The non-OEM won't.
Motorcraft and IH are OEM types. There are probably others (Fram?). Wix is not.
I still have three of the original six Wix filters that I ordered from Fleetfilter for about $13 each. Thought I was getting a deal. One was used, two were wasted trying to figure out why my oil bypass system wasn't working - turned out to be the filters. Anyone wants my leftover Wix oil filters, pay the shipping.
My .02.
Al
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
