Originally Posted by 05 Excursion
Hello this is my first day on here. I have a 05 Excursion runs good then stumbles alot once I am on the highway and up to speed. Then when I am in the city and try to leave from a stop light the truck wont go white smoke and then black smoke and away it goes like nothing is wrong. Any Ideas?????????? The check engine light is now on and tells me its #5 glow plug is not working. I have also found lots of reports about the FICM messing up and I have the diagrams to repair the soilder problems. I will also check that EGR tonight, change the Glow Plugs and Re-soilder the FICM. Hope this works.
Don't assume anything.
To properly check your FICM requires that you remove the batteries from the truck, bring them somewhere to have them LOAD tested. If they fail, replace them.
The second step in checking your FICM is to charge the batteries fully. Do not assume that because the truck turns over rapidly that the batteries are charged. VERIFY that they are by putting each on a battery charger.
The third step in properly checking your FICM is to click on the following
link and following the directions to the letter.
If your FICM fails the check after properly preparing for it, and you have supreme soldering skills, follow the repair procedure. If your soldering skills are anything like mine (seriously lacking any skill), do not attempt to repair it yourself. The reason I say that is if you were to attempt repairs, and fail, then decide to send your FICM to someone along the lines of SWAMPS, they will not refund your "core" charge. They would have to fix the repair you attempted, then repair the FICM.
Next, I highly recommend that you install a set of gauges, NOW. The link in my signature line, "Basic Info" will explain to you the gauges you need, why you need them and what to watch for.
I suspect that your "white smoke" could be steam, and, if I am correct, you are flirting with disaster every time you crank the engine over. Cylinders 5 and 7 typically see some strange things happening just before your head gaskets fail. The coolant could be building up in those cylinders while your truck is parked, and that could be why the glowplug in that cylinder is throwing a code.
Theres a long explanation for all this, but your oil cooler clogs, that slows the coolant flow to the EGR cooler and the EGR cooler overheats and then it fails internally. That failure allows coolant to flow into the exhaust stream. When the EGR valve opens, it sucks that coolant into the intake manifold and down into the cylinders. When the EGR valve is closed, the coolant is flowing out of the EGR cooler the opposite direction, and enters the exhaust stream through the passenger side up-pipe, then goes through the turbo, then exits the truck through the exhaust system. Sometimes, under low throttle conditions, this can present itself as steam out the exhaust.
When you switch the engine off, the coolant, being under pressure, will still flow out into the exhaust, into the passenger side up-pipe. BUT now that there is no airflow to force the coolant flow upwards to the turbo, it will flow into the passenger side exhaust manifold, and should an exhaust valve be open, it will fill that cylinder with coolant. This is why I say that every time you turn the truck over, you are flirting with disaster.
This is what I
think could be happening. Theres a reason why your truck is smoking, find that reason. Do not ignore it or it will cost much much more in the long run.
