6.0 powerstroke runs rough after starting - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 01-14-2009, 09:46 PM Thread Starter
I have a 2005 6.0 powerstroke dually that runs rough after starting and pumps white smoke out of tailpipe until engine comes up to temperature. Ususally take 10 minutes. Does anybody have any ideas as to how to fix this. It is worse in cold weather, but does it any time the engine temperature drops after sitting overnight. If I plug in the block heater, the rough idle and white smoke go away more quickly. We live in Angleton, Texas so it's not real cold on the gulf coast. I'm not familiar with the term "reflash" which I have seen on other posts.
madmax01 is offline
post #2 of 3 (permalink) Old 01-15-2009, 07:21 AM
rock_doctor's Avatar
A year or so back ford released a new software update for the computer. The software (flash update or reflash) actually sends power to the injectors to warm then up (while you are waiting for the glowplugs to warm up) then once you start the truck the injectors are less likely to stick (stiction) and operate normally. The complaint for the flash is a rolling or rough idle, white smoke at start up and hard starting. You appear to have two of those. You may consider spending the $100 or so dollars and have it flashed to the induction flash. It likely will solve you cold running issues. Do a search for "induction flash" to read more. If by chance you are still under the 3/36 warranty it will not cost anything but if not then it will cost 1hr of shop time which is generally ~$100. Good luck.
rock_doctor is offline
post #3 of 3 (permalink) Old 01-15-2009, 10:34 AM
Just got my 05' back from the doctor for the same problem. They replaced 4 injectors that were misfiring at start up. No ruff running issues at start up now.
Mark
2011 F-450 4x4 Crew PSD with everything but the sunroof.
42' XLR 385x12 TH
40' GN Millennium Trailer for racing
Sold 2005 F-350 4x4 Crew Auto
Sold 2001 F-250 4x4 Crew 6sp
mdmasters is offline
