6.0 Problem - Diesel Forum - TheDieselStop.com
Old 03-30-2009, 08:43 PM   #1 (permalink)
XXcumminkillaXX6.0's Avatar
6.0 Problem
The other day started the truck.. wet humid day the temp around 50 degrees. the truck started really hard. gave it about 5 minute to warm up but sounded like it was running on all 8 cylinders. about 15 minutes later i put my foot to the floor tires started spinning at about 3000 rpm then truck flies to 4000 rpm stayn there my foot to the floor.. lost all power until i let my foot out of it then went back to normal. has doen this a couple times and i think an injector is staying open to long or something.. hope i made it clear enough hard to explain. please help should i take to dealer.
06 ford powerstroke 2"inch lift xd series dick cepek fc2 w/ sct custom tunes, 4" turbo-back mbrp exhaust.
XXcumminkillaXX6.0 is offline
Old 03-30-2009, 09:06 PM   #2 (permalink)
can you pull any codes with your programmer sounds like a weak ficm
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
