6.0 Rough First Start and idle without any Power - Diesel Forum - TheDieselStop.com
Old 01-25-2010, 11:04 PM   #1 (permalink)
cyclone3565's Avatar
This is my first diesel and Thank you for having me.
I just bought a 2004 with the 6.0 L and have a couple of questions. I test drove it in the afternoon and it ran great, almost can't feel it idle with more power than I could shake a stick at.
Well, the next morning I started it, after waiting for the glow plug, and it sounded like !$%Q@$%. I let it idle for a minute and then crawled through our neighborhood. I think I would have had more power on my bicycle. It idled high, would not shift and I had a hard time getting over 10 mph. After a few minutes it got better but took probably 10 minutes to feel the way it did when I test drove it.
This weekend changed the oil, filter, fuel filters, air filter. Also noticed a strong exhaust smell behind the turbo. Maybe a minor improvement this morning
I spoke with with a Ford Diesel mechanic this morning and he recommended that I remove the butterfly inside the throttle, but leave it all connected electronically. He believed that one of the flash updates actually deactives it. He was quite certain that by removing the butterfly it would help with the rough, no power upon the first start in the morning.
Now for the exhaust smell in the engine compartment, back behind the turbo. These fumes also enter the cabin while sitting at a light. After speaking with him, he told me that 60 to 1 it is the Y pipe, which I am going to switch out this Saturday.
Any and all suggestions would be greatly appreciated. Am I over ananlysing this and should not worry about it.
Thank you very much
Martin
cyclone3565 is offline
Old 01-25-2010, 11:32 PM   #2 (permalink)
tattoocharlie's Avatar
My Photos: (5)
Thank you very much
Martin
well im not sure if the 6.0s have a ebpv or not,but,the 7.3s do.they help warm up the engine,during this the truck will feel like it doesnt want to move,really sluggish.(ebpv=exhaust back pressure valve)
2002 f250 lariat 7.3 200k(motor has 170k)
original 4r100 tranny....200k and counting
knock on wood......
tony wildman chip......
stock,economy,daily,towing,extreme,smoke.
red elc good for 150k
4r100 1-2 2-3 3-4sonnax accumulator valves,.427 sonnax line pressure mod valve
4.125"yes thats 4 1/8" diy tymar intake(size matters...lol)
AIH delete,ccv delete,zoodad mod,
4" exhaust no muff
built my own leafs for 4.0 of lift!!!!!!
18" xd bronze revolvers with 325 nittos to wrap them
isspro pyro and boost guages on pillar mount....
tattoocharlie is offline
Old 01-26-2010, 12:00 AM   #3 (permalink)
teamroper60's Avatar
Originally Posted by tattoocharlie View Post
well im not sure if the 6.0s have a ebpv or not....
They don't. They have an exhaust backpressure sensor but no valve.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 01-26-2010, 08:26 AM   #4 (permalink)
hitecdan's Avatar
My Photos: (22)
Some early 2003.25 power stroke engines have the throttle plate (EGRTP), some, not all. I have an early 2003 and it did not have the thorttle plate.
Page 38: Air Management System
Yours may or may not have one, but it's easy to check. The EGRTP was deleted in the 2005 MY.
2005 Update Page 06 Exhaust Up pipe Scoop-Intake Manifold Divider Plates-EGR Throttle Plate
My want to check out the high pressure oil pump or ICP sensor. A weak/leaking pump can cause cold start/running issues.
My html Version of the 6.0L Bible Now with 2005 Updates
$5 AIC
Born on date: Jan 20, 2003
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 4/15/2010)
The United States Constitution © 1791, All Right Reserved.
hitecdan is offline
Old 01-26-2010, 08:43 AM   #5 (permalink)
I will check that tonight. Do you think that, if I do have it, removing it will help with some of the morning issues?
Old 01-26-2010, 10:34 AM   #6 (permalink)
I would think letting it warm up for a little while before driving it in the mornings would help...
F250Ghost is offline
Old 01-26-2010, 11:18 AM   #7 (permalink)
I did let it warm up for a few minutes, still did not have full power
Old 01-26-2010, 11:35 AM   #8 (permalink)
speedrcr78's Avatar
Ford has an updated heating strategy that solves this problem. Also yo could have an injector going bad or bad.
speedrcr78 is offline
Old 01-26-2010, 04:05 PM   #9 (permalink)
Ya, for some reason it sounds like some type of sensor or injector. You might have to have a diesel mechanic do a diagnosis for you sometime because the last thing you want to do it let the truck warm up for 30 mins every morning just so it runs normal.
QuoteWarz Insurance is offline
Old 01-26-2010, 05:27 PM   #10 (permalink)
Took it to Don Davis today, they were great!!!!Eddie reflashed and checked everything, all looks good. He believes that the new flash should take care of it along with my removing the butterfly from the throttle. Will update in the morning.
Old 01-26-2010, 09:01 PM   #11 (permalink)
the rough start up could be your FICM (fuel injection control module) the exhaust smell is probably cracked bellows on the y pipe to the turbo.
hinesy is offline
Old 01-27-2010, 05:56 AM   #12 (permalink)
Eddie at Don Davis in Arlington tested all injectors and the FCIM for me as well. Hopefully the flash will take care of this. He also agreed that the bellows are probably cracked. I am planning to replace the Y pipe this weekend.
Old 01-27-2010, 08:56 AM   #13 (permalink)
WOW, what a difference, starts right up, idles smooth and had much better power in the morning. Shifting was also much better. It is amazing what software can do.
Old 01-27-2010, 01:43 PM   #14 (permalink)
Cold Starting
Seems that I have a similar problem, except, when mine actually starts, the power isn't bad, but I do have to let it run for about 5 mintues to get the "clacking" to go away.
I just recently started having problems starting my 6.0 in my Excursion. The engine seems to be cold (outside air a balmy 41 degrees). If I wait for the pre-heater light to go away, crank it, maybe one or no cylinders fire and kick over. I turn off the ignition and try again, it turns over a little more, until after about 10 times it actually starts (and sounds really bad, as in in a noisy cold engine).
After warming up, no problem starting through out the day. Could it be that my pre-heater is out? How hard is that to change?
Other possible problems? Car has been virtually maintenance free and has only a measly 98k on it.
Any ideas would be appreciated, as I am a diesel novice.
Scott
Southern California - Irvine (not exactly cold country)
speotter is offline
